Radar detector smart cord install for CL-S
Old Sep 1, 2007 | 02:57 PM
2CLean's Avatar
Well...it's kinda fast...
Just hardwired my Bel Pro RX65 with smart cord, what do you think? I think the smart cord mounting location looks pretty clean. I mounted the RD high for the best radar coverage and it's most sensitive to laser scatter from this location (trust me, I've experimented) plus from the outside you can hardly see it (so I don't have to take it down everytime I park for fear of it getting stolen). Also, I still have full use of the passenger side visor and complete range of motion for the RVM. Mounted the smart cord display so that I could mute it or change volume within arms reach.
I know there's been other threads, but I don't think I've seen it mounted here before. Not sure how large the V1 concealed unit is, so I don't know if it would work, but for Belscort (Beltronics and Escort) units that use the smart cord it's almost a perfect fit.
Old Sep 1, 2007 | 03:49 PM
BigLizard's Avatar
Moderator Alumnus
cool
Old Sep 1, 2007 | 04:04 PM
cbusAcuracls's Avatar
Looks good!
I like the location..is it easy to see from the driver seat?
Old Sep 1, 2007 | 05:55 PM
Allout's Avatar
Blown is Best
Looks good. How did you attach it?
Here's where I hung my V1 but I loose the use of my visor on the passenger side. Not too much of an issue since I ride alone most of the time.
Old Sep 1, 2007 | 06:11 PM
JJ92799's Avatar
Blah Blah Blah
I was gonna install mine there but I was afraid the window tint would have an affect on the detector picking up signals
Old Sep 1, 2007 | 06:16 PM
2CLean's Avatar
Originally Posted by cbusAcuracls
Looks good!
The RD itself is completely visible from the driver's seat. The concealed display is kinda obscured by the steering wheel but I don't use it for the visual alert aspect. Mainly there so I could mute/change the volume easily.
I attached the RD using the supplied bracket/suction cups mounted up near the headboard on the dot matrix tint strip, with the sensor just below the strip. I think the V1's a little too big to mount there and not hinder either the RVM or the PS visor. As long as you use new/properly conditioned suction cups they should stick securely to the raised dot matrix.
The concealed unit is just friction mounted between the 2 pieces of plastic but is suprisingly secure.
I hear ya, that's why I made sure the sensor itself is just below the tint. I've experimented, and the tint really only hinders laser which isn't a concern for some, but for me it was since KY State Police use laser pretty much exclusively on the HWY.
Old Sep 1, 2007 | 09:59 PM
poisx7's Avatar
i have the Escort Passport 8500 Radar Detector , i just put it on the middle of the winshield. i wish i could install it like that but it looks too big to fit in such a location.
anybody with suggestion on locations or pics. I will like to kindaoff hide it from outsider view but in such a way that i can still see it form the driver's side (functionality)
http://www0.epinions.com/Radar_Detec...range_280_1105
Old Sep 2, 2007 | 10:37 AM
2CLean's Avatar
Since you can't mount it high (I know the x50's are longer than the Bel's) you've actually got it in the next best place, centered and directly under the RVM. Only thing is, it's pretty visible from the outside when you have it there. You could always do what Allout did and get a visor mount. You would just lose the functionality of the ps visor, but it would be hidden on the outside. The higher up the better for radar, but not as good for direct LIDAR hits (unless you have a V1). Mounted in the middle is the best compromise.
Old Sep 2, 2007 | 10:59 PM
nbennettksu's Avatar
i heart latin chicks
I like the location...some companies say not to mount it there becasue the sun blocker on the top "hinders its reach" but I think its fine...
Old Sep 3, 2007 | 05:32 PM
poisx7's Avatar
Thanks 4 the advice.
what is direct LIDAR ?? maybe i will get the V1 i payed $300 for the 8500 when it came out. been great, that things works veryveryveryvery well. Been there
Old Sep 3, 2007 | 07:17 PM
2CLean's Avatar
Sorry, LIDAR (Light Detection and Ranging) is the tech term for laser, which isn't really laser, but ultraviolet light shot in a focused beam.
Old Sep 3, 2007 | 07:40 PM
ML03CLS's Avatar
This post motivated me enough to hardwire my V1 after owning it for 2 years.. It is currently mounted on the windshield just under the rearview mirror and the wiring took MAYBE 10 minutes to run and hook up.
Thanks!
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
chrisr
Dec 4, 2015 02:17 AM
sockr1
Oct 1, 2015 01:31 AM
deyainrdy4ds
Sep 22, 2015 10:15 AM
TxRzrBk
Sep 17, 2015 01:07 PM
