q about our engine
Old May 9, 2001 | 02:14 AM
snubotch's Avatar
q about our engine
if our engine is inline 6 shouldn't all the exhaust be on one side of the engine instead of what it is right now.
white type s
piaa bulbs
xephyr cai when ever it gets here
Old May 9, 2001 | 02:17 AM
beestea's Avatar
We have a V6, BMW has the inline 6.
Old May 9, 2001 | 02:22 AM
superdds's Avatar
Fight On SC!
not necessarily.
2001 silver cl type s
Old May 9, 2001 | 02:54 AM
snubotch's Avatar
<font face="Verdana, Arial" size="2">Originally posted by superdds:
not necessarily.
</font>
well...you can't just say that and then leave me hangin limp like dat
white type s
piaa bulbs
Old May 9, 2001 | 02:56 AM
Iridium130's Avatar
w.t.f., mate?
<---Coulda swore it was a V6 not an I6
Bimmers and the IS3 have an I6
We have a V6
_-Phil-_!
2K1 #10,029 Satin Silver CL-S since 6/13/00 named Laetitia with Navi! Mods : XEPHYR PERFORMANCE CAI~3M Reflective Tint(37%) tint~Hiper Hibrid Plasma "Xenon" road lamps & high-beams~Uniden LRD 6599SWS Radar Detector~Shine by Meguiar's Gold Wax~Member of the Scratched Rims Club~Upgraded cupholder ~
Old May 9, 2001 | 03:12 AM
snubotch's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Iridium130:
We have a V6
</font>
you're right it is a v6...i just check edmunds
white type s
piaa bulbs
Old May 9, 2001 | 03:48 AM
Iridium130's Avatar
w.t.f., mate?
<font face="Verdana, Arial" size="2">Originally posted by snubotch:
</font>
_-Phil-_!
Old May 9, 2001 | 11:16 AM
gto2050's Avatar
Someday pigs WILL fly!
It still poses an interesting question.... since our V6 is mounted trasnversely so there basically are no "sides". The exhaust manifolds start in the middle. So it must just be cosmetic that they decided to run them out right and left side and not the middle.
01 CL-S NightHawk Black/Ebony Bowling Ball Interior
Old May 9, 2001 | 11:26 AM
tel1sps's Avatar
It does not matter if ya have a V6 or I6. Dual exhaust can be put on both engines.
2001 Silver 3.2CLS
Muds, Spoiler, Hardwire 8500, Polarg M-6 lamps, K&N filter #33-2178,
Comptech Headers, Sways, mufflers
Planning: SSR 17X7.5 GT1 Wheels, Brembo Brakes.
Old May 10, 2001 | 03:56 PM
superdds's Avatar
Fight On SC!
</font>
look underneath your car. the split for the dual exhaust is around the rear axle. you can easily just have the exhaust pipe flow into one muffler. but the dual exhaust looks meaner.
Old May 10, 2001 | 05:02 PM
scalbert's Avatar
<font face="Verdana, Arial" size="2">Originally posted by gto2050:
</font>
The engine is mounted transversely so the pistons and crank run from left to right. There would be no way for the manifolds to be in the middle, intake ports are already there. One head on top of each bank of three cylinders. Having 4 valves per cylinder 'requires' the plug to be at the very top with the valves surrounding it. Two for intake and two foe exhaust at each cylinder.
Looking at a cross section of the heads you would see the ports and valves at an angle on the head. The intake and exhaust ports on opposite sides.
On our car and pretty much all V6's the intake ports are to wards the center of the engine, for a good reason. Since the block has the cylinders at an angle, 60 degrees on our car, the intake ports face more up allowing flow from the intake manifold an easier path and better packaging. Secondly, if the exhaust ports were on the inside all of the plumbing would be run in the 'V' of the engine. This would be difficult to make the bends and allows allow for heat build up. It would probably over tax the cooling system.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
