Put on UR Crank Pulley Today.....
Old Apr 12, 2003 | 08:02 PM
ChucksTL_RENAMED's Avatar
Very decent gains, about like a CAI but the engine spins better from starting and thru every gear. Gear changes are instant and VTEC comes on like NOW rather than BAWAAAA like before. It feels like the gains are what UR says they are, about eight or ten at the wheels. I didn't do the other pulleys as it would have been alot more money and they are mostly for looks. The crank pulley was about $240 shipped or close to it. To put it on I had to remove the front right side wheel, remove the Alt. belt and P/S belt (after removing the motor mount) and then voila the pulley bolt would not let go! Even with the air compressor at 120 lbs and a high power gun ( I/R 2131) it wouldn't budge so I had to hit it with a torch for 20 seconds and it came right off. The two new belts need to be slightly shorter as the pulley is slightly smaller. It weighed 2 lbs, the stock one 8.5 on the trusty bathroom scale.
I have a 00' TL-P with I/H/E, I guess now it's I/H/E/P.
Old Apr 12, 2003 | 08:30 PM
purplehaze's Avatar
The Liquidator
Very cool.Did u dyno her yet? do it and tell us.
Before putting on the Crank pully did u find out about possible side effects of it? can it mess up somethin in the car?
Give me more details if u can.
Congrats
PH
Old Apr 12, 2003 | 08:51 PM
For now I'll have to rely on the butt dyno, but there's no question that it spins like it's lighter and rev's way faster.
I called UR and had a long talk with the tech guy first. He said our cranks are balanced internally and that Honda uses just crank pulleys on our engines, not harmonic balancers. Why it is so heavy stock I just don't know. For the pulley part number and belt part numbers just go to their web page. He also said that if it would hurt an engine they wouldn't sell it. He said while other brands produce gains by underdriving, they limit that part to 15% and the rest is from weight savings. I can tell you the engine idles exactly the same as before and revs up totally smooth, no added vibration at all, zero. So I too hope that it will be a good mod that will last a long time.
Old Apr 12, 2003 | 09:52 PM
sidemarker's Avatar
wow 240 bucks just for one pulley! but as long as it gives good gains i guess its worth it
sidemarker
Old Apr 12, 2003 | 10:42 PM
darrinb's Avatar
///M POWER
i'm thinkin about gettin pulley's, but they are a rip off
Old Apr 12, 2003 | 11:32 PM
allmotor_2000's Avatar
I'm getting the entire set next week... $290 for the full set. The clutch should also be in probably the week after. I think the combo (especially the flywheel) will give 20-30whp gain on the dyno. The UR pulleys alone give 13whp dyno-proven... and that's like a 6-7lb reduction in mass right on crank. The flywheel/clutch is like 12-15lb reduction, so I am expecting very good gains If these bolt-ons can get me to 275whp... 300whp won't be too difficult.
Old Apr 12, 2003 | 11:43 PM
darrinb's Avatar
///M POWER
thats only for the 6speed right allmotor??
Old Apr 13, 2003 | 08:39 AM
Aquineas's Avatar
Disproportionate Member
I have one for my Alti, I can't say enough about this mod. I got the same results: noticeable increase in how fast it revs. For the Alti, it was a great bang-for-the-buck mod (I got in on a $115 group buy).
I can believe the 6-7 lb weight reduction from stock; the stock pulley is heavy.
Old Apr 13, 2003 | 10:36 AM
ferizzo's Avatar
still a Masshole
240 for a pulley that gives upto 10 hp is no different than paying 200-250 for a CAI that gives about the same power. I'm thinking about getting the UR crank pulley eventually as well but I want to see if there are any long term side effects.
Old Apr 13, 2003 | 10:50 AM
sidemarker's Avatar
i understand that but i thought 240 would also include the powersteering and alternator pulley as well
so how much is for the full set??
sidemarker
Old Apr 13, 2003 | 11:22 AM
mr tl's Avatar
when you removed the pulley didnt you have to hold it in any way, to prevent it from spinning?
what did you torque it to?
Old Apr 13, 2003 | 11:24 AM
Titand19's Avatar
East Coast Boost.!
Hey guys, I'm sorry about not getting on that groupbuy for you, I've been busy as hell with finals coming up and the end of the year, I'll try ot get on it tomorrow.
Old Apr 13, 2003 | 05:40 PM
dfv3.2CL-S's Avatar
I thought that the pulleys were not go for our engine due to not having a harmonic balancer. I heard that it can damage the internal parts from the engine down the road. 40to 50K miles range. Is it worth it?
Old Apr 13, 2003 | 06:50 PM
Mr TL - I had the 50mm holding tool that I got from a tool guy but didn't end up needing it as the torch allowed just the use of my 1/2" impact gun to spin it off. That tool was $42!!! Torque is 181 ft lbs, or 245 newton meters when going back on. I just used a 1/2" drive SK torque wrench. If anyone needs it just PM me.
Old Apr 13, 2003 | 07:48 PM
mr tl's Avatar
thats what i thought. $42 seems pretty decent compared to prices i got
good to know the torch helps
Old Apr 13, 2003 | 08:52 PM
flint's Avatar
Where did you purchase the pullies from? Seems to be a good price.
Old Apr 14, 2003 | 04:16 PM
NJTypeS's Avatar
I've had the pullies installed since 9/02 and absolutely no side effects.
Old Apr 14, 2003 | 10:54 PM
flint's Avatar
I think I will go with the UR pullies since I seem to be in a Mod rut.
Old Apr 14, 2003 | 11:02 PM
SFLA_Type-S's Avatar
Sold 12/29/04 :-(
Has anyone tried combining the AEM pullies with the UR crank pulley? I just bought the AEM's, but wouldn't mind adding the UR at the crank. Any thoughts (allmotor2000)?
Old Apr 14, 2003 | 11:04 PM
Titand19's Avatar
East Coast Boost.!
Get UR, Aem does practically nothing, they are more of a cosmetic mod.
Old Apr 14, 2003 | 11:20 PM
Sold 12/29/04 :-(
It's too late, I already have the AEM's. I would also add the UR crank pulley if I was able to.
Old Apr 14, 2003 | 11:53 PM
mattg's Avatar
i think thats a big
Old Apr 15, 2003 | 08:55 AM
AtlCl's Avatar
Not AtlCl98 or Atl-CL
Hey Allmotor, I thought that you are not supposed to put a lightweight flywheel and a lighter crank pulley together on the same engine; that it would break some shit. I have read that you can only have one or the other, but not both. Explain please.
Old Apr 15, 2003 | 10:02 AM
I wasn't aware of such a 'rule'. If it blows.. it blows, lesson learned right?
Old May 21, 2003 | 11:03 PM
Caddy©'s Avatar
Don't you hate it when your in a "MOD RUT" !
Old May 22, 2003 | 11:23 AM
CLS2001_97124's Avatar
Revving at 9K...
How much do you guys think it would cost to get the UR Crank Pully installed?
Old May 22, 2003 | 11:35 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
$100-$150
SidhuSaaB
May 30, 2020 12:40 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
STL TL-S
Sep 23, 2015 08:52 PM
NSolace
Sep 3, 2015 08:14 PM
