Problems after cleaning TB
Folks,
I finally cleaned my TB but ran into problems after putting everything together. Engine light is ON and after I rev it up, it seems to run between 1500 and 2000 RPM by itself....don't know what's going on...I tried to search if anyone has had such problems but didn't find any post....any help will be appreciated...
did disconnect battery for 30 minutes...check engine lights was gone...put my foot on gas pedal and same thing....car starts find but after i put gas to it, it revs between 1000 and 1800 RPM...i opened the hood to see what was going on...heard some sucking noise...so checked all the hoses to make sure they were tight...I couldn't find anything wrong....and now the check engine light is on again...
pits your post did not come up in any search...i used stuff from Pep boys meant for cleaning throttle body...
someone pls help
someone pls help
https://acurazine.com/forums/2g-cl-2001-2003-50/help-throttle-body-cleaning-car-wont-start-703433/
This won't solve the problem, but it does sound like a vacuum line is disconnected somewhere. Also it could be that somehow the IAC may need adjusted.
But it may just be that some of hte stuff you used to clean it is still inside and is clogging up some of the sensors (throttle position sensor, Map sensor) and this is causing the issue. I just kept my car running for like 15 minutes till everything burned it's way out.
The IACV is bad. You might have to replace it. I had the same problem you're having last week. I replaced it and solved the idle lope. It is a known problem for the 01-03 CL, 99-03TL, older MDX and Oddessys. The new replacement IACV are supposedly improved over the old.
The IACV is not supposed to be adjusted. It' ECU controlled. If it was working before the TB removal then it shouldn't need to be adjusted.
Whatever you used to clean the TB may have damaged the sensor connector, or the TB gasket is not sealing right. Did you use a new gasket? Your suppose to after taking the TB off.
Thanks Guys for your suggestions...i kept the car running for 15 minutes...took it around the block for 10 minutes...did not feel anything abnormal...may be its the leftover stuff in the TB as pits said...i will use the car for few days and find out if the problem goes away or i need to put in a new IAC sensor....i did change the gasket but it sounds like its most definitely the cleaning liquid that could have damaged the sensor if sensor turns out to be the problem...
http://www.acuraoemparts.com/delray/...LVE_SET_%28%29
billmcd
ILX
Oct 17, 2016 03:33 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
brandnewcolony
Sep 12, 2015 10:39 AM
