Problem Starting car
This morning, I was goin to use My 03CL-S and the car did not want to start. I turn the key about 5 times and it made the noise like it wanted to start, but never turn over. The battery is not dead according to my charger and base on the all the dash light and stereo they turn on with no dimming side effects. Yes! the clucth was depressed during the attempts. No belts are broken as I can see into the engine bay. What the heck could be going on with the car? The car only has 5678 miles and it always garaged.
Re: Problem Starting car
That happened to me (once). I don't know what it was but she would crank and crank but not start. I gave it a little gas pedal input, and she started right up. Hasn't happened to me since, so I don't know what it was.
On fuel injected cars, your not surposed to give it any gas, but I was brought up on carburators. When they used to flood out, you could sometimes get them to start with the gas pedal to floor (or opening the butterfly all the way).
Some times cars are just tempermental, more of a bitch then a machine.
Originally posted by dallison
i'de like to see the tow bill for me b/c i am 2 hours away from the closest dealer
my car used to stall when i depressed the clutch on a cold engine....it did it about 6 times total....but only in the first 10K miles or so...after that...it stopped.....so im not worried anymore
Every once in ableu moon these cars have the odd no start .We have never had much luck trying to diag this off the wall problem as it is so ultra rare when it does happen .Unless it is a continous problem I would not get too concerned .Just a car being a car .
Jens
Jens
The promblem is gas for winter changes ,in a couple of days it will be normal.I have that promblem every time I go out of state,and when I come.
You need triple A's Gold package for towing. They will tow up to 100 miles.
Hard to have dealer diagnose intermittent problems like that but sounds like the starter must be at fault....
