Problem Starting car
Old Nov 25, 2003 | 11:51 AM
dfv3.2CL-S's Avatar
This morning, I was goin to use My 03CL-S and the car did not want to start. I turn the key about 5 times and it made the noise like it wanted to start, but never turn over. The battery is not dead according to my charger and base on the all the dash light and stereo they turn on with no dimming side effects. Yes! the clucth was depressed during the attempts. No belts are broken as I can see into the engine bay. What the heck could be going on with the car? The car only has 5678 miles and it always garaged.
Old Nov 25, 2003 | 12:33 PM
GreenMonster's Avatar
Re: Problem Starting car
Time to call the dealer. I was going to say, make sure the clutch is pressed all the way to the floor, but I guess you've got that covered.
That happened to me (once). I don't know what it was but she would crank and crank but not start. I gave it a little gas pedal input, and she started right up. Hasn't happened to me since, so I don't know what it was.
On fuel injected cars, your not surposed to give it any gas, but I was brought up on carburators. When they used to flood out, you could sometimes get them to start with the gas pedal to floor (or opening the butterfly all the way).
Some times cars are just tempermental, more of a bitch then a machine.
Old Nov 25, 2003 | 12:38 PM
pgatour1's Avatar
Could be a faulty starter.
if it is, tow truck, and parts and service are under warranty.
Old Nov 25, 2003 | 12:47 PM
Syncros-CL6's Avatar
Mine did that once too at about 5000 miles...it finally started after about 5 tries and hasnt done it since...I have 23K now....I drive too much
Old Nov 25, 2003 | 12:49 PM
dallison's Avatar
registered pw
i'de like to see the tow bill for me b/c i am 2 hours away from the closest dealer
Old Nov 25, 2003 | 12:51 PM
pgatour1's Avatar
Your tow bill would be Zero, Acuras on the other hand would be $55 for intial and first mile and whatever it is for each additonal. I don't know a dollar or so. so maybe $175.
Old Nov 25, 2003 | 02:58 PM
DivinDude's Avatar
Yup .. my '03 6er did that too .. wouldn't start at all .. starter cranked .. but nothing .. dealer "we can't reproduce it .. no problem"
Old Nov 25, 2003 | 03:15 PM
my car used to stall when i depressed the clutch on a cold engine....it did it about 6 times total....but only in the first 10K miles or so...after that...it stopped.....so im not worried anymore
Old Nov 25, 2003 | 04:06 PM
Jens H.'s Avatar
retired
Every once in ableu moon these cars have the odd no start .We have never had much luck trying to diag this off the wall problem as it is so ultra rare when it does happen .Unless it is a continous problem I would not get too concerned .Just a car being a car .
Jens
Old Nov 26, 2003 | 07:07 AM
dfv3.2CL-S: Any update ??
Just curious if it was a onetime thing or if you had a problem that the dealership needed to address.
Old Nov 26, 2003 | 01:13 PM
johntypes's Avatar
The promblem is gas for winter changes ,in a couple of days it will be normal.I have that promblem every time I go out of state,and when I come.
Old Dec 1, 2003 | 04:18 PM
dfv3.2CL-S's Avatar
It has happen twice in a 8day period, but know the car turns over fine and runs normal. I dont know the what is going on.
Old Dec 1, 2003 | 04:30 PM
Eggplant-EX's Avatar
You need triple A's Gold package for towing. They will tow up to 100 miles.
Hard to have dealer diagnose intermittent problems like that but sounds like the starter must be at fault....
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
