P2R Billet Intake Manifold Plenums
#201
Originally Posted by PowerRev
You can't just make a spacer for the factory plenums, as you will then hit the valve covers. Yes it would be cheaper, but it will not clear unless they area really small. The way we were able to make these bigger while still clearing valve covers and hood, is that we kept them big towards the outside, where as factory rounded theres in. And we kept it going straight as far as we could until we saw clearance issues.
Since these are being made on a small level right now. I can not send them all for anodizing if someone would like to get one raw. It will not be an issue.
from tov: one lap of america honda racing oddesseys:The #72 car went a few steps further, incorporating a Honda Pilot intake manifold spacer for more low/mid range torque.
![](http://www.hondaautomotiveparts.com/auto/jsp/mws/catimgs/14s9v01_e0301.gif)
#203
Originally Posted by typeR
id think something like the oddessey lower intake spacer ,which is about the equivalant of two outlaw spacers would raise the upper intake enough to just have a plenum spacer using the stockers ...could be wrong ...maybe the equivalant there of say 10 gaskets? id say some one could take a gasket to a shop with cnc and get them to recreate the gasket out of aluminum about .5 inches thick ...and hey im in no way tryin to take away from what power rev has done ...the cost for theres is justified ,but if the same thing can be achieved for less im also all for that ...im gonna paste a section from TOV about the oddessey lower intake spacer...
part number 3 20$
I didn't know they had that, and that's a very important mod to gain some midrange power. That's essentially what thermoblok spacers/gaskets whatever you want to call them do. There was one person on here to doubled the thermalbloks up. I really don't think thermoblok reduce intake mani temps as the bolts that hold the manifold to the runners soak up the heat and spread it to the manifold, so after 30 min of cruising, your mani temps are the same imo. I think the gains they are seeing is because of the elevated manifold.
Some of you older guys may remember cruising around with holly 850's on their old cars with tunnelrams or carb spacers, you could get up to a 2 in spacer to fit under the carb, this acted as a tunnelram so to speak. It acts like a high rise manifold. That spacer on the oddesy is the same concept.
As for the P2R's plenums, it's a fantastic idea and a great looking mod. If I was still in the mode to mod my current cl, I'd jump on these. With P2R getting them anodized that's even better. Anodizing is not expensive and you can get them in a variety of colors. I'm partial to the TypeS red.
#204
Have you ever looked at a engine in a Oddyssey. Its sits very low, I am not sure if you tried that spacer out yet, but on my Cl, there is not a ton of hood clearance. So I am not sure if that would make the intake manifold hit the hood or not. Thats more of the reason why I do not want to bring the intake up to much, but would rather create the volume from the plenums, which will not make the intake manifold sit any higher, and then you can still port out your intake manifold.
The J series engines have so much potential, its a shame that there are not many people going in depth with them to try and create big Hp like we are doing. You guys are goin to flip out when I show you the recent dyno graph of my turbo J30 Civic
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#205
The J series engines have so much potential, its a shame that there are not many people going in depth with them to try and create big Hp like we are doing. You guys are goin to flip out when I show you the recent dyno graph of my turbo J30 Civic![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#208
Originally Posted by CleanCL
well someone did double up the thermoblok spacers... i forget the exact thickness, but i believe each one is about 1/4 inch thick, so by doubling thats roughly a 1/2 inch up and he had hood clearance. i'm also planning to do dyno testing w/ double up spacers and also trying your thermal gasket to see what happens.
#214
remember RES it would clear ...maybe have to notch or remove the fiber underhood cover thingy but i think theres plenty of room for that spacer
#215
#216
yea... it's a $20 part but that doesn't include the longer bolts and 2 gaskets you need to buy. not saying that would stop me from doing it... but it's a little more complicated, do the egr ports line up? bolts are same thread?
I thought of the same thing yesterday. The gaskets are $16.33 a piece, you need to get longer bolts, and yes who knows they may be a different thread, and the egr ports may not line up, and you may have to do a little under the hood to make some more room. I think I may go ahead and order everything and see how it goes. In the end it will be $20(spacer) and $32.66(gaskets) for a total of $52.66. I think its worth it to see.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
How are those plenums coming, I am still in for those either way.
#217
One more note, sorry I couldn't edit my last post. The Pilot bolts are 8x105, the TL-s bolts are 8x65. Also matching up the illustrations the gaskets look like a match so I don't think these will be an issue, but there is only one way to find out. We shall see.....
#218
![](http://www.hondaautomotiveparts.com/auto/jsp/mws/catimgs/14s9v0_e0311.gif)
#219
I talked about this years ago on the TL side. I matched up a set of gaskets from the TL to the pilot spacer and they matched. I just never went thru with it (due to trans #3 failure at the time) Im not sure if the S guys will be able to use it due to clearance issues but the P motors can take it without problems.
#220
#222
that's about a 1.5" difference... figuring in the need for extra thread length, the spacer is probably slightly more than 1" which i think is even more than doubling up the thermobloks...
#223
Well opened up the hood this weekend and decided to see how mcuh room I would have if I were to do the Pilot spacer. So I took 2 pieces of wood that were a tad bit smaller than the top of the intake manifold and were also roughly an inch thick each, total of two inches. The hood didn't come close to closing. SH*T!!!!!! The only way I see to do it is to get a different hood, or are my methods of testing space wrong.
Soooooo........how are those plenums coming
#224
Uses turn signals in my
Update from my side: Sean from P2R said we may be able to get them on sometime this week. I just spent all weekend working extra hours for an Apexi Neo. I have the money for that now and plan to order it on monday.
#225
Soooooo........how are those plenums coming![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
#226
#227
No I didn't take off the fiber underhood cover.
CleanCL......not if I beat you to it, I as well had ordered the parts before I tried it this weekend. Hopefully they will be showing up in the next day or so.
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
#228
4drs just wanna have fun!
i already purchased all the parts... ill let everyone know how it turns out.
Wish I had the hood clearance to do this, already have no insulation and cut hood supports. Looking foward to the results, hey so what ever happened to the cams you were testing anyway? Any thoughts on the TLS cams retro'd to fit our heads (ie cam gears etc)?
#229
CleanCL......not if I beat you to it, I as well had ordered the parts before I tried it this weekend. Hopefully they will be showing up in the next day or so.![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
#230
I dont have the clearance to install them with the type-s motor in my TL-P or id install them as well. As it stands im VERY close to hitting the hood with the motor.
#233
Former Sponsor
Originally Posted by fuzzy02CLS
PowerRev
I may give you my 6mt to test if you still need it. What kinda of time frame are you looking at? How long would you need it?
#234
CL-SEXY SIX (=
Sup guys, i just ordered a set of the P2Rs intake plenum from Excelerate. I have to get it dynos before and after. Don't know any dyno places around the NY area. Wondering if anyone here from the NYC area can come with and show me a place.
#235
#236
Adventurist.
contact Josh on dyno info, i'm on LI and getting a set of plenums too.. we should dyno the same time.
I think I can guinea pig my car but I won't be back in town until the end of this month. My car will feel neglected once again...
#237
Originally Posted by NiteQwill
That's a great idea as each car will always pull a different set of numbers. Leaves less chance for error.
#240
CL-SEXY SIX (=
Sure, just PM me. And we swap info from there.
Where in LI are u locateD?
