oil question...
Old Sep 3, 2007 | 03:24 PM
Kasper's Avatar
Registered Newbie
oil question...
What's up everyone...I bought my '01 CL-S two weeks ago today, and had a question about the oil. I checked it when I got home from the dealer, and it was full and very clean, so I'm sure the dealer changed it recently. Is there a way to find out if the car was running synthetic oil? And I just saw a post with someone saying these cars run 5w20. Is that right? My car just broke 74,000 miles so I'm trying to figure out a maintenance schedule, and the correct type of oil I should be running...
Thanks for any info you can give me...
Old Sep 3, 2007 | 03:34 PM
2CLean's Avatar
Well...it's kinda fast...
You could always have the oil analyzed, but really it doesn't matter if it's synthetic or not. If you want to switch to synthetic go ahead, if the internals are in good shape you shouldn't have any problems with leaky seals switching from dino to synthetic.
I use Mobile 1 syn 5w20 and filter with change intervals every 7.5k to 10k miles. Any more frequent than that and you might as well use dino .
Old Sep 3, 2007 | 03:40 PM
Kasper's Avatar
Registered Newbie
I didn't want to switch to synthetic if I didn't have to, but if I could go up to 10k without changing the oil, it should still be about equal in cost comparison to regular oil and more frequent changes then right? I was running Mobil1 in my last car but was changing it every 5k. I definately won't be running the cl-s as hard, so 10k per change is safe?
Old Sep 3, 2007 | 03:59 PM
ML03CLS's Avatar
Couldn't have said it better myself.. Mobile 1 Synthetic at 7.5k intervals, any more frequent than that and you're throwing money away.
The only problem I have with 10k intervals is the filter itself, but I wouldn't be surprised if they are fine as well.
Old Sep 3, 2007 | 04:06 PM
Kasper's Avatar
Registered Newbie
The filter was always my worry at 5k, but I guess I was wrong. 7500 miles is sounds do-able. I only drive 15 miles to work, and I pretty much just cruise. Guess that's not much more, especially if I'm babying it most of the time. So, going with Mobil1 with 74,000 on the odometer, what weight should I be using?
On a side note, I'm just starting to read up on this whole tranny issue. Being that I'm still under 100k, could I get the tranny replaced if need be, or is it only for original owners?
Old Sep 3, 2007 | 04:28 PM
2CLean's Avatar
Mobile 1 extended performance filters are good for up to 15,000 miles. That's what I use. Acura actually suggests change intervals at 7.5K on dino, so 10K on synthetic should be no problem.
Old Sep 3, 2007 | 04:43 PM
o1s's Avatar
o1s
tranny warranty automatically transfers. and i use mobil 1 fullsynthetic 5w20 and change it whenever the maintenance reqired light starts blinking.
Old Sep 3, 2007 | 06:53 PM
Kasper's Avatar
Registered Newbie
Thanks for your guys' help. I'll definately be popping in, trying to learn more about the car as I go. I'll post some pics and stuff when I start putting some money into her. It's all stock for now though.
Old Sep 3, 2007 | 08:18 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
Mobil 1 fully synthetic is on sale at the walmarts over here for $19.94 for a 5qt bottle. I have mine sitting here next to my pc for my next oil change.
Old Sep 3, 2007 | 09:13 PM
nbennettksu's Avatar
i heart latin chicks
I use 5w30
Old Sep 4, 2007 | 05:55 AM
labmeister's Avatar
USTHS76
Originally Posted by nbennettksu
I use 5w30
That's what I use, too. Also in owner's manual and oil cap. I'm sure 5w20 is OK, too.
Old Sep 4, 2007 | 10:39 PM
Allout's Avatar
Blown is Best
Are you sure it's a 5 qt jug? I bought a Mobile 1 jug that I thought was 5 qts and it turned out to be 4 qts.
Old Sep 4, 2007 | 10:53 PM
LIPPSTUH's Avatar
Unregistered user
yup it was 5 qts, walmart has it for pretty damn cheap.
Old Sep 5, 2007 | 11:13 AM
It says 5qts on the jug, so it should be, unless mobil or walmart are pulling a fast one.
Old Sep 5, 2007 | 12:38 PM
thevikas87's Avatar
Your mom is in
my transmission died yesterday at 68k miles....acura dealer called this morning saying they ordered a tranny for me and it should be done by saturday covered under the warranty...i hope your tranny dies before 2008 cause after december 2007, you'll be out of luck
Old Sep 5, 2007 | 12:49 PM
dnd2984's Avatar
Valvoline Synpower is great to.
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
