Oil Leak in My CL 01
My car is a CL-P 01 gold color with 85,000 miles on it and the type s look. Original tranny(Knock on wood) I start to see some oil leak( Motor oil) . I check the drain plug and oil pan and all look Ok!. this morning I try to check again And maybe come from between the motor and transmition But I,m not pretty sure. Any sugestions and help I Really appreciate.
I,m newbie in the forum.
Your new friend from Puerto Rico!
Originally Posted by CL in PR
I really dont know.Maybe need to call to Acura Of Puerto Rico And verify my car is in warranty and cover this expensive job! for $ 8.00 part. The transmition need to be removed?
At this moment is not leaking bad,just a little.But recently a Acura technician take a ride in my CL and said my transmition is smooth and shifting perfect So i dont know how much time take to my trans die.(Maybe soon) and I need to check the motor oil every two days and verify is oK! Damn!
It shouldn't be that bad you have to check it every two days?! If so then it needs to be fixed ASAP. I've had cars in the past with leaking rear main seals and they still only needed to be topped up once a month or so. Weekly check should be good unless it's a severe leak. If it's leaking that bad the whole underside of the car from the motor back will be wet with oil! If just the close area around the tranny is wet then it shouldn't be that bad. Is there a pool when the car is parked?
The reason I check every two days is just to prevent.let me tell you something my CL is used every day so I put a lot of miles on it . more is used ,more oil leak. And more Fu@#%$% Money In motor oil to refill. That the reason.Today I call Acura of Puerto Rico(Excelent Customer Service!) And taLk About My problem they said this job is not cover by warranty because of my car is done (Damn!!) . transmition warranty 1 year Left ( 7 years or 109,000 Miles) i dont know what to do just deal with it until my transmition warranty expire and for other car or Pay for this expensive repair .
IBankMouse
06-13-2020 12:53 PM
