O2 Sesor
Old May 26, 2003 | 09:59 AM
juice's Avatar
O2 Sesor
How do you disconnect the wire at the sensor?
Old May 26, 2003 | 10:11 AM
EdgarFanCLS's Avatar
Masshole
If it's like the O2 sensors I've seen before, the wire goes from the base of the sensor to a plug. That plug is where it disconnects.
Old May 26, 2003 | 10:27 AM
juice's Avatar
I am talking about the kind on a '01 CLS. It has a metal cap on it. I am not sure if it unscrews are unplugs.
Old May 27, 2003 | 10:10 PM
juice's Avatar
Someone knows how to disconnect this!
Old May 28, 2003 | 10:44 PM
juice's Avatar
Somebody answer me!!!!!!!
Old May 29, 2003 | 06:49 AM
Masshole
What has a metal cap on it?
The O2 sensor won't unplug right at the sensor. Try following the wire that comes out of it until you reach a point were it attaches to another wire via a plug or something else. That's probably were it disconnects. Every O2 sensor I've seen attaches that way.
Old May 29, 2003 | 07:41 AM
Jens H.'s Avatar
retired
Juice ,go look at the O2 sensor and then follow the wires from the O2 sensor to the plug .On a CL/S or TL/S series car the lugs are located as follows: Primary O2 sensor has a 4 wire grey connector that is located directly above the differential ,to access it you go from the top of the engine compartment .For the secondary O2 sensor you must be underneath the car ,it is also a 4 wire gray connector located this time next to the passenger side frame rail between the rail and a heat shield in that area of the car .
Jens
Old May 29, 2003 | 11:33 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
I don't know! I couldn't figure the damn thing out! I ended up just unscrewing the thing... damn plug !
lankanboy1
Nov 23, 2025 02:03 PM
aCuracOupebabiixOx
1G CL Problems & Fixes
Jul 4, 2011 10:43 PM
srm clgy
1G TSX Problems & Fixes
Dec 24, 2005 12:01 AM
