o2 sensor defouler
Old Aug 17, 2010 | 12:16 AM
SexyCLS's Avatar
o2 sensor defouler
Where can i buy one?
or can it b made?
i need one b4 this month ends i need to pass inspection
im catless
Old Aug 17, 2010 | 01:07 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Blox makes a straight one's.
Old Aug 17, 2010 | 04:55 AM
Rajca's Avatar
wham bam thank you ma'am
car parts store. autozone, orileys (sp?), ect...
Old Aug 17, 2010 | 12:30 PM
SexyCLS's Avatar
I Think i found the part
is this it?
http://cgi.ebay.com/ebaymotors/O2-SE...item3efa3ea72e
Old Aug 17, 2010 | 12:57 PM
ANC297's Avatar
Bonki' Ehrite!
Im pretty sure you can just use a spark plug defouler, cant you?
Old Aug 17, 2010 | 01:07 PM
Rajca's Avatar
^yes. 2 of them to be exact.
Old Aug 17, 2010 | 01:26 PM
SexyCLS's Avatar
How do i make one can someone call me to explain better?
Old Aug 17, 2010 | 02:07 PM
ANC297's Avatar
Bonki' Ehrite!
Just buy them from Autozone or whatever parts store you go to.
civicdrivr's Avatar
Go to Autozone, pick up a two pack of spark plug defoulers. Drill out the bottom of one of them (someone help me out, I forgot what size drill bit) and screw the modded defouler into the other unmodded defouler. That now screws into the secondary (rear) O2 bung and the O2 sensor goes into that. No more CEL.
Old Aug 17, 2010 | 04:15 PM
gnuts's Avatar
3.5 psi
i need to do this. I get a code every 2 months or so. how come you can't use one defouler?? All i know is that it gets the o2 sensor out of the direct exhaust flow and that somehow makes the CEL go away?
Old Aug 17, 2010 | 04:24 PM
Rajca's Avatar
Half inch hole I believe
Old Aug 17, 2010 | 11:54 PM
civicdrivr's Avatar
1/2" sounds about right.
Gnuts - It doesnt matter, just as long as the secondary O2 is out of the exhaust stream. That O2 just acts as a sniffer, it doesnt control anything, just makes sure the cat is doing its job.
Old Aug 18, 2010 | 08:28 AM
p.diddy's Avatar
Got mine from napa autoparts. Haven't had a cel since.
Old Sep 19, 2016 | 09:04 AM
dvrice's Avatar
Any more info or instructions on this? I don't need to pass any testing, but the "check emission system" light comes on sporadically on my 2007 MDX and is annoying as hell.
Old Sep 19, 2016 | 11:11 AM
gnuts's Avatar
3.5 psi
what code is being thrown? is it for the 3rd cat or one of the primary sensors? If it's for one of the primary sensors then you should replace those.
there's no instruction needed. remove the sensor, screw on the defouler, screw sensor back in.
RobbDizzle
Oct 15, 2015 11:16 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
