New shocksensor install pics
Old Sep 13, 2001 | 12:38 AM
NOVAwhiteTypeS's Avatar
Here are instructions w/ pics on how to install it.
Make sure you click on the picture to get the instructions for each pic.
http://public.fotki.com/novawhitetyp...ensor_install/
Old Sep 13, 2001 | 12:58 AM
Type S's Avatar
Powered By HONDA
what kind of shock sensor do u have and how much is that and where do u get that..thanks a lot...
by the way..how lond do u spend to install that..thank u..buddy
Old Sep 13, 2001 | 01:03 AM
updated the first pic instructions to include where to get it. autotoys.com
and total time about 10 min MAX. the hardest part is finding the wire and trying to cut the like 20 pieces of the 3m tape in to little sections.
Old Sep 13, 2001 | 01:52 AM
SilverKnight's Avatar
Retired. Not available.
Originally posted by NOVAwhiteTypeS:
<STRONG>updated the first pic instructions to include where to get it. autotoys.com
and total time about 10 min MAX. the hardest part is finding the wire and trying to cut the like 20 pieces of the 3m tape in to little sections.</STRONG>
10min Max??? damn, you are getting good
Old Sep 13, 2001 | 01:55 AM
Originally posted by SilverKnight:
<STRONG>
10min Max??? damn, you are getting good </STRONG>
yeah no more taking out all that prong and crap. MUCH easier to just find the wire. if I have someone cutting the electrical tape for me than like 6 or 7.
Old Sep 13, 2001 | 11:23 AM
willang's Avatar
Nova,
I used the instructions you posted in August and installed my shock sensor which I got from AutoToys.
It was easy to install the sensor but the sensor is not sensitive enough or perhaps the place I mounted it on is too insulated.
AutoToys sent me a dual stage shock sensor encased in black instead of your clear casing. The sensor (model ALA95) is made by Magnadyne.
I know the sensor work as I tried activating it by tapping on the dash (I was in the car) after arming the car and the alarm went off.
But even when I was rocking the car on the outside, the sensor just does not activate the alarm. I already set it to max. sensitivity.
Please let me know the ideal place to mount my sensor. Thanks.
Old Sep 13, 2001 | 03:28 PM
Rocking the car will not set off the alarm. for that you'll need motion sensor. this is for shock. like when someone hits your car w/ there door or try to break a glass, pry your headlights out. Mine seems to work fine where I have it mounted in my picture. My next project was too add a motion sensor w/ it. For the people who have yet not done this I would recommend may be a motion/shock sensor.
Old Sep 13, 2001 | 03:34 PM
WOAH!!
i just checked my fotki site, and i had 395 hits and 75 visitors!!! whoo hoo!!!
donations can be sent to joekim13@hotmail.com
Old Sep 13, 2001 | 03:43 PM
AntsAreCrap's Avatar
Where do you connect the blue/white wires? Why do you connect them together? What are they intended to connect to?
Why is the sky blue?
Old Sep 13, 2001 | 04:19 PM
Originally posted by AntsAreCrap:
<STRONG>Where do you connect the blue/white wires? Why do you connect them together? What are they intended to connect to?
Why is the sky blue? </STRONG>
the blue/white connects to the yellow w/ silver dots. they sky looks blue because....
Old Sep 13, 2001 | 04:30 PM
I've got $20. Do you mind stopping by this weekend?
Old Sep 13, 2001 | 04:34 PM
Okay i just limited my service to 300 miles from va.
OMG everyone go to www.fotki.com look on the left and you'll see me as one of the top visited member in the last 24 hours. Jeez i put the shocksensor stuff up last night.
<<Joe Kim
as soopa said
AKURA 0wnZ j00!!
Old Sep 13, 2001 | 05:15 PM
NOMAD's Avatar
Midnight Marauder
Excuse my ignorance, but if you just buy a motion sensor wouldn't it do also serve as a shock sensor? If it's hit in the parking lot, a motion sensor would go off right?
Old Sep 13, 2001 | 05:17 PM
all depends on the impact on how hard it is. im no alarm expert but I do no this is better than just the stock. not perfect but does its job.
Old Sep 13, 2001 | 05:24 PM
JZ's Avatar
JZ
Joe--that is an excellent tutorial. What do you htink about the install of the motion sensor? They have one at autotoys for 10 bucks. An ideas on wiring?
Old Sep 13, 2001 | 05:26 PM
Originally posted by JZ:
<STRONG>Joe--that is an excellent tutorial. What do you htink about the install of the motion sensor? They have one at autotoys for 10 bucks. An ideas on wiring?</STRONG>
Exact same wiring jon, If you don't feel like doing it on your own. I can do it for ya. just bring the sensors and may be a bottle water for me.
Old Jan 1, 2002 | 10:38 PM
HIREN's Avatar
A-CL Member
how would i wire in a motion sensor? and where would i mount it
doesnt really say where to mount it on that how-to
Old Jan 1, 2002 | 11:12 PM
haiduc's Avatar
Moderator Alumnus
hey.. have you done one on a first gen.. if you're willing you can lab rat my car for the install.
Old Jan 1, 2002 | 11:32 PM
IWuvMyCL-S's Avatar
... and my CL-S wuvs me
NOVAwhiteTypeS, those are EXCELLENT photos and instructions!
2 questions:
- On pic #1, your link to efunctional.com isn't working correctly. Which sensor should I be using?
- On pic #5, somebody left a comment about why the 2 wires are spliced together? He says you could use the dual stage function if they're not wired together. Would that work?
Thanks again! Those instructions ROCK!!!
Old Jan 1, 2002 | 11:55 PM
KavexTrax's Avatar
Food for thought:
what would it take for a kill switch, i.e. a fuel cut-off trigger
btw, Great job Joe!
Old Jan 2, 2002 | 07:35 AM
woah! this thread is like mega old. I had to check twice on the date. well thanx.
kvx, sorry no idea on the kill switch.
wuvcls- try www.efunctional.com and browse to the car alarm section. any dual stage shock sensor will do.
the reason why I used a dual stage is because it will elminate false alarms and your alarm will ONLY go off when both 1st stage and 2nd stage is triggered.
if you want the alarm to go off every time for every little sound/shock use a single stage and if you don't want false alarms use a dualt stage
Old Jan 2, 2002 | 09:54 AM
juniorbean's Avatar
LOL, Nova, I was thinking the same thing when I saw this up top!! To those who haven't done this yet, I bought my dual-stage sensor at autotoys.com (I think it was around $12 or so) and I used Nova's directions. Actually, I didn't do the install, a friend of my father's did (he does alarms, etc. on the side). No joke it took him less then 15min.... so these directions have been proven to be awesome and detailed!!
Old Jan 2, 2002 | 02:35 PM
HIREN's Avatar
A-CL Member
so would a motion sensor work if i installed it the same way?
Old Jan 2, 2002 | 02:48 PM
Crazy Bimmer's Avatar
Yes it would.
Old Jun 3, 2002 | 02:36 AM
tw1112's Avatar
So are the wires the same for the 1st gen? Still yellow with silver dots? Sorry to bring this old one up I'm going to try and install this this week for my 1st gen and also add a shock/motion sensor for my dad's new camry. I asked in the audio/elec forum, but does anyone know how to do this for the camry's?
Old Jun 3, 2002 | 04:56 AM
actually no they are not cause the 1st gen's don't have a hood switch. or do they? not sure
Old Jun 3, 2002 | 01:40 PM
tw1112's Avatar
So I am looking for the trunk or hood switch wires?
Old Jun 3, 2002 | 03:32 PM
cnatra's Avatar
Thanks for the info.
I need to do that!!
Old Jun 3, 2002 | 03:35 PM
NO.
First of all, your car has to have stock alarm. Keyless entry is not qualified as "alarm".
The shock sensor trickes the stock alarm to think the hook or door or trunk is opened while the system is armed, so the alarm goes off.
Old Jun 3, 2002 | 04:08 PM
tw1112's Avatar
NO.
Eh? As far as I know I have the same thing as the 2nd gens do....keyless entry with a panic button and horn if tripped. Also if the door were unlocked from the inside, the alarm goes off. Is this what your talking about?
Old Jun 3, 2002 | 05:38 PM
tw1112,
Yeah, that would work.
For those who keep asking about dual stage and proximity sensor. They WILL NOT work without some sort of special external circuitry. Your stock alarm is single stage triggered. How are you gonna hook up dual stage triggered? Regarding proximity sensor, yeah, you can install the sensor, but as soon as it detects motion, the alarm goes off. So go ahead install it and have fun listening to the horn that goes off every 30 sec.
Old Jun 3, 2002 | 06:01 PM
Type S's Avatar
Powered By HONDA
thansk for the info but how much are all materials??thanks
Old Jun 3, 2002 | 07:46 PM
juice's Avatar
I have done this installation a few months back. The instructions work great. Thanks.
I used the exact same dual stage sensor as the instructions call for. I only installed one, but have another that I would like to add.
My only complaint is that it is not sensitive enough. Has anyone used a single stage? If so, please post the info on where I can order one?
If no one has done this, NOVAwhiteTypeS - could you please recommend a single stage shock sensor to use in the application?
Thanks,
juice
Old Jun 3, 2002 | 07:50 PM
tw1112's Avatar
Thanks silverknight!!! I will try this out soon as I get the sensors.
For those looking for sensors you can go to www.autotoys.com and they ought to have what you need.
Old Jun 3, 2002 | 11:22 PM
Thanks,
juice
I'm no NOVAWhiteTypeS but I guess I could answer your question.
If you get a sensitive sensor, you would have to set it to the least sensitive level like I did. Back then, a UPS truck was enough to set mine off. So the problem is with your sensor.
If you could locate a instant trigger (aka single stage) sensor, then it would be perfect. Originally, I was forced to use dual stage because I couldn't locate a single stage so I put "dual stage" in my template.
Old Jun 3, 2002 | 11:33 PM
juice's Avatar
Thanks.
I found this one, http://store.autotoys.com/cgi-bin/wfp53024.storefront .
Do you think this one will do the trick. It looks like it is adjustable.
The link does not work. Go to autotoys.com. Do a search on shock sensor. Go to the second page of results. Click on Result # 13.
skathe
2G TSX Performance Parts & Modifications
23
Apr 10, 2020 06:36 PM
SinCityTLX
63
Mar 23, 2016 02:13 PM
bailey24
Nov 21, 2015 08:43 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
alan_rich
Sep 9, 2015 11:38 AM
