Need Help !!! Tranny Problem ??
Old Dec 5, 2005 | 07:54 PM
optionet's Avatar
Today, my car start acting weird, when I put it in Park or Neutral, my rpm will jump up and down between 500 to 1500. Then all the sudden, it will go down below 500 and the car die. THen later on the night, same thinig keep happening and my check engine came on. Could that be Tranny Problem or something else ?
My car is 2001 and currently has 70k miles, still is the 1st tranny. I also have Stone Headers, if I take it to dealership, will dealership deny my warranty because of that ? SHould I take out the headers, I really dont want to since it was "pain in the ass" to uninstall then install it again.
Thanks in advance
Old Dec 5, 2005 | 07:55 PM
phipark's Avatar
Not Asian
See if you can get the code pulled first, then reply here with the code. Most likely, it's your IACV or idle air control valve. You might need to clean it or replace it.
Old Dec 6, 2005 | 08:16 AM
optionet's Avatar
so u dont think its about the tranny? Someone also told me it may be the altnater
Anyone else has the same problem or suggestion ?
Old Dec 6, 2005 | 11:38 AM
phipark's Avatar
Not Asian
I doubt it's your tranny. You said your problems occur when it isn't even in gear.
Old Dec 6, 2005 | 10:10 PM
optionet's Avatar
yea... hopefully its nothing big !
Old Dec 6, 2005 | 10:20 PM
aceofharps's Avatar
It's some kind of bad sensor. My 98 CL recently had the same symptoms. Gonna cost you some bucks.
Old Dec 8, 2005 | 02:04 AM
optionet's Avatar
well should I take out my headers or just leave it ? The headers are pain in the ass to take out and put on
Old Dec 8, 2005 | 08:59 AM
phipark's Avatar
Not Asian
The dealer shouldn't void your warranty, but every dealership is different. However, I don't see a reason for them to complain about it for this problem.
Also, have you even checked the IACV? Why take it to the dealer for that? It's fairly simple to fix or replace. If you can install headers, you should be able to clean and/or replace the IACV.
Old Dec 8, 2005 | 04:40 PM
optionet's Avatar
actually I didnt change the headers myself... hehe
where is the IACV located ???
Does anyone have the part number ? or do I have to order from the dealership ?
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
