Lighting question
Lighting question
Okay, I got my PIAA lights in today to replace the reverse lights and the licence plate light. Anything special I should know. I think scooter has done all of these before. I'm not very mechanically inclined, so any tips before I try to do this on my own would be greatly appreciated
Originally posted by Chinisimo
don't touch the glass w/ your fingers cuz the oil on your skin can make the bulb heat up and eventually burn it out. just one of the things i can think of now
ok, let's attack the reverse first:
1. the black knobs on the inner wall of the trunk right behind the light housings are really screws to hold the lining secure...so unscrew them and pull the lining away
2. the reverse lights should b the easiest bulb to get access to, so b careful when removing the light
as far as license plate light go, all u need is a phillips head screwdriver, and yer set
Originally posted by nate'sCLS
Gawd, its not like brain surgery... remove the friggin bulb cover and "unscrew" the bulb, then "screw in" the new ones... My goodness!!!
nate'sCLS: I know it's not that hard, but this wonderful resource is out there, acura-cl.com, so i figured i would take advantage of it and make sure there was nothing weird I needed to be aware of. My bad.
Originally posted by NoleCLS
Thanks for the info scooter, I will have new lights as soon as I get home today.
mmmmmmmmmm, blue
Just wondering what you guys think of the PIAA lights...I went with the full package short of the high beams and mirror lights...the bluish lighting complements the aegean blue exterior nicely IMO.
I think I paid 9 bucks for my roadlamp bulbs, but I can't remember...
Originally posted by Scrib
How much did that cost you???
remember to either wear surgical gloves or use a towel to install the PIAA's...and the reverse lights are pop out/pop in, so it's a piece of cake
mmmmmmmmmm, blue
mmmmmmmmmm, blue
Oops
How could I forget to mention that surgical gloves are required, I guess it is sort of like brain surgery
Mine come in a box like this...
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
