JENS: back seat removal
Old Mar 28, 2001 | 11:22 PM
CLpower's Avatar
teh Senior Instigator
how do i remove the back seat on my 3.0???
i have the service manual and it only explains the front seat.
"the needle got buried at 140.....1,500 RPM later...the tach got buried"
Old Mar 29, 2001 | 01:47 PM
CLpower's Avatar
ttt
do you know where the bolts are?
Old Mar 29, 2001 | 02:02 PM
4mula1's Avatar
First you want to remove the bottom part of the seat. Pull up on the front of the seat(the part where the back of your knees would be if you were sitting in the back seat. Pull it straight up, this will release the back portion of the bottom at the same time.
Repeat for the other side. This will expose four bolts for the backrest portion of the seat and tho for the center console. When you remove these the center console will pull right out. You then want to lift the rear section of the seat.
Replace in reverse order
Old Mar 29, 2001 | 02:17 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 4mula1:
</font>
is this for the new CL? cause i have the 1st gen. I tried lifting the bottom up and it wouldn't go.
Old Mar 30, 2001 | 10:48 PM
CLpower's Avatar
TTT
Old Mar 31, 2001 | 11:12 AM
Jens H.'s Avatar
retired
It has been a long time since I took one out let me just verify my memory.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Old Mar 31, 2001 | 12:56 PM
DigiBox's Avatar
Lots of JDM parts on my
There should be two release levers on each side of the seat. They are between the carpet and the bottom of the lower seat. You have to pull the lever out and then lift lower seat. It should pop out. It would probably be easier to do one side at a time. Once that is gone, you will have no trouble getting to the bolts for the other part of the seat.
[This message has been edited by CiLver2.3 (edited 03-31-2001).]
Old Mar 31, 2001 | 05:26 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CiLver2.3:
</font>
ya i found the levers, so i pull out right?
Old Mar 31, 2001 | 05:28 PM
DigiBox's Avatar
Yup, just pull on them. They don't come all the way out. They move just enough to release the seat. Pull on the handle, then lift the seat.
Old Mar 31, 2001 | 05:34 PM
CLpower's Avatar
Yup, just pull on them. They don't come all the way out. They move just enough to release the seat. Pull on the handle, then lift the seat.</font>
what handle?
Old Mar 31, 2001 | 05:36 PM
DigiBox's Avatar
Sorry, I meant the levers. They are only big enough to get a couple of fingers through.
Old Mar 31, 2001 | 10:56 PM
CLpower's Avatar
Sorry, I meant the levers. They are only big enough to get a couple of fingers through.</font>
where
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
d.lim
Sep 15, 2015 08:54 PM
truonghthe
Sep 7, 2015 11:17 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
