J32a2 mag sensor?
Old Jun 30, 2012 | 10:16 AM
Lumpy's Avatar
J32a2 mag sensor?
Does the j32a2 have a MAG sensor? Need to know because Im buying a AEM FIC and there not compatible w/ the MAG sensor.
Old Jun 30, 2012 | 11:41 AM
YeuEmMaiMai's Avatar
do you mean MAP or MAF sensor?
Old Jun 30, 2012 | 02:42 PM
civicdrivr's Avatar
I think hes referring to the difference between Mag and Hall sensors.
I will answer your question with another question.
Do you have an auto or manual?
Old Jun 30, 2012 | 08:09 PM
Lumpy's Avatar
Its the MAG sensor. I have the J30 wire harness w/ the J30 Auto tranny (2000 Accord) and the J32a2 engine. Im trying to get something to tune it and raise my rev limiter to 7200rpm. The J30 only has a rev limiter to 6200rpm. Not sure what the MAG sensor is, but I guess its not compatible w/ the AEM FIC. So I guess the ? would be does the j30 wire harness have a mag sensor or the j32a2 engine have a mag sensor? If so, what can I buy w/ my set up that I can tune & raise the rev limiter?
Old Jun 30, 2012 | 08:47 PM
Lumpy's Avatar
AEM's website is showing one compatible w/ the MAG sensor. I just need to know if I have MAG sensors so I know which one to get.
Old Jun 30, 2012 | 10:15 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
j32a2 from a 6-speed uses hall sensors, the other j32's use mag sensors. this is a quote from paul:
The FIC does not work well with the MAG sensor set of the older Js, if you are building a older J then use a EMB.
the only thing that can raise your redline is an ems series 2
http://www.aemelectronics.com/series...a-j-motor-1112
Old Jul 1, 2012 | 07:35 AM
Lumpy's Avatar
Thanks for the info. Im gonna call AEM tech support on Monday and figure this thing out,
Old Jul 2, 2012 | 07:26 PM
Lumpy's Avatar
Talked w/ AEM and looks like the only way Im gonna be able to raise my rev limiter is to go w/ the AEM EMS series 2 30-6051 ( Thanks rp_guy). The FIC's wont do it. With the EMS, wideband 02 sensor, dyno and tuning Its gonna cost about 2gs. Hope Its worth it, lol. Will post dyno results when I get them and then 1/4 mile times after that.
Old Jul 2, 2012 | 08:38 PM
civicdrivr's Avatar
Ummm, you said your running an auto tranny.....the EMS wont control that.
Old Jul 3, 2012 | 07:54 AM
Lumpy's Avatar
Does anyone know of anything that will work? Sent AEM a email, hopefully they have something.
Old Jul 3, 2012 | 08:36 AM
AnthraciteTypeS's Avatar
6mt swapped..smart
Yea the EMS only works with a 6mt using an auto harness and mag sensors from an auto as well. I want sooo bad
Old Jul 3, 2012 | 01:39 PM
civicdrivr's Avatar
You can try Ronnies (J&R) piggy-back system, it may work for you.
TypeS860
Jan 10, 2026 11:11 AM
Jul 16, 2017 07:33 AM
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
