High Flow Cat
Old Jul 9, 2007 | 11:40 AM
Blasted69's Avatar
03 Anth Type S 6 Speed
Post High Flow Cat
Does anyone know of any bolt on high flow cats for an 03 cl-s 6 sp? Also is there a difference between 6 sp and A/T for this part like there is for others?
Thanks!
Old Jul 9, 2007 | 11:46 AM
6sp_03's Avatar
There is a cat back called ...random technoloy high flow cat... that will work for the 6speed, the automatic is different.
Old Jul 9, 2007 | 11:49 AM
distortedolskool's Avatar
SEARCH for random technology Cat. i believe excelerate sells them on the forum.
first link with some general info
https://acurazine.com/forums/showthr...dom+technology
and where they are sold
https://acurazine.com/forums/sponsored-sales-group-buys-10/random-technology-high-flow-cat-sale-tsx-cl-tl-350743/
in the first link it should discuss the widening of the mounting plate holes and extending the O2 sensor wires that must take place on the 6spd.
Old Jul 9, 2007 | 12:21 PM
2CLean's Avatar
Well...it's kinda fast...
I don't know of any aftermarket cat that is a direct bolt-on to the Type-S (auto or 6speed). The Random Tech cat is a direct bolt-on for the CL-P, and as stated earlier, requires slight modification to the flange. Personally, I would buy a universal R/T cat (with the larger inlet) and have a muffler shop weld the correct flange(s) to bolt up to the factory down pipe and b-pipe.
Old Jul 9, 2007 | 09:10 PM
m733l's Avatar
i have the rt cat for my 6 speed. rt only makes one model and it is a direct fit for the cl-p as stated. i got it to fit my cls6 with minor modification. nothing you could not do yourself with a drill and drill bit. basically need to drill the holes out a little larger so that the holes will line up better to the header and b pipe. excellent mod
Old Jul 9, 2007 | 09:38 PM
nbennettksu's Avatar
i heart latin chicks
you got to mess with the flanges. also the cl-s cat is longer than the cl-p's
Old Jul 9, 2007 | 09:43 PM
CleanCL's Avatar
are you sure? the cat is different, but the physical length i believe is the same, since all catbacks fit the cl-s and cl-p.
Old Jul 10, 2007 | 12:13 AM
Excelerate's Avatar
Former Sponsor
The RT cat bolts up to the Type S and Premium model jsut the same. Both require extension of the 02 wires, but the Type S requires slightly enlarging the holes on the flange on the B-pipe to cat. And from what I understand from other members you don't even need to modify the flange if you have a stock exhaust.
Old Jul 10, 2007 | 09:04 PM
not 100% sure, but in this thread: https://acurazine.com/forums/ramblings-12/first-napster-now-189511/ biglizard/gm and mclarenf lead me to believe the cat on the cls was a little longer
Old Jul 10, 2007 | 09:06 PM
not 100% sure, but in this thread: https://acurazine.com/forums/showthread.php?t=189511 biglizard/gm and mclarenf lead me to believe the cat on the cls was a little longer
I thought thats why they didnt make a b-pipe for the clp...?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
