high beam light bulb
Say I am sure this was mentioned before:
I was wondering if I could use the regular bulbs to replace the highbeams so they can match. If they are not compatible, do you guys know of something that is close to it?
thanks
thanks
Re: high beam light bulb
thanks
thanks
If you want cheaper, get the Nokya Arctic White 9005. Got them for $25 at autocarparts.com
I love them. They also show a blue color when in the housing. Much much brighter than stock.
I'm curious... has anyone tried the Phillips 9005? They're cheaper than the Solaris ($17 per bulb, I think?) http://www.autolamps-online.com/prod...05bvcentre.htm The blue color looks more subdued which I like.
say what if I use the same type of bulb the low beam uses for the hight beam?
so what's the closest bulb I can get that matches the low beam for the high beam light bulbs? And where can I get it?
thanks,
thanks,
I replaced my high beams with PIAA Super Whites for $60. They are much brigher than stock, a good match for the low beams and barely show any blue when turned off.
I bought mine at:
http://www.thepartssource.com/piaa_s...eplacement.htm
I bought mine at:
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
