View Poll Results: Once you go black, you never go back?
Voters: 16. You may not vote on this poll
Which headlight housing shall I go with?
What's crackin?
So here's whassup...I'm having headlights sent on over to Mr. to get cleared, and possibly blacked out. I have an '01 SSM CL-S so that should give you some kind of an idea. Now here are the options:
A) Cleared
B) Cleared & Black Housing (these are on a TL)
another look at it
Here's the problem....I want mine to look IDENTICAL to the 03's...as in, leaving the turn signal and reflector area chrome, like the following:
However, Mr. says that he can only do balck housing like the 2 in option B because if I wanted it like the 03's, he'd have to mask off the chrome area and that could strip the chrome surface away. Basically, if I want to get black housing, the turn signal and reflector areas would have to be black as well. So help me out fellas (and ladies
`John
A) Cleared
another look at it
)`John
lol......and oh yeah
I'd like to thank CHRIS for even putting the black housing thought into my head!
so you guys think it'll look coo even w/ the corners painted black?
p.s. that IS your name right? I've met one too many people this past week.
whoa soopa, that looks gangsta
do you have a pic of those on a car by any chance? I wonder what it would look like painted silver on a SSM??
btw, could you tell Mr how to do that? Because I don't want the reflector area painted black. Thanks
pics on the car:
for all the people who PM'd me on how to mask the reflectors...
simply buy the LOWEST tack painters tape you can find... scotch makes a type that is so low stick it wont even cling to your fingers. but its sticky enough that it will lightly attach itself to the chrome and create a seal... but is peelable without stripping the chrome. i've found this works best...
you can find these types at SOME hardware stores... some Home Depots carry it. otherwise go to a Art Supply store... they have it.
alternatively... and for the set of lights depicted here... I used electrical tape. that works too... but it is sticker then other low-tac masking tapes.
for the LOWER reflector area... simply take out the orange reflector... cover it with tape... then put it back into place. this will create an excellent mask and takes 10 seconds.
the upper area... first lay tape along the edges to define the line you want. then fill the area with soft toilet paper... then lay tape over that to secure it. this will make sure no paint gets into the reflector area and wont hurt the chrome.
ive used this method for over a dozen '01 CL lights... and i've used it on several other makes/models. it works.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
