Header Sound Question
Back to a MT!
I installed my XS Power headers this weekend and it wasn't bad other than the cat bolts we had to grind off, which was made easy by just removing the whole exhaust system from the car. Anyways, the power and exhaust note are nice, but I hear a rushing of air sound (not sure if its a leak of not) when I'm driving and step in the gas. It doesn't do this when there is no load on the engine. So I redid all the connections agian last night and still sounds the same. I'm guessing its (1) of (2) things: just the normal sound of more air rushing through the whole intake and exhaust system or a gasket is leaking. I checked around the flange areas and didnt' see any exhaust deposits, but its only been a few days. Anyone thoughts on this.....
In the Mid-South meow
there was a thread about the bolts that the XS headers come w/ are too small I think they're 8mm and somebody said if you put 10mm in it stops that leaking sound. I found it at work and copy/pasted it to my home email so heres what I have if you havent seen it already.....
Replace those 8mm shitty bolts that come w/ the headers and go to the auto parts store or hardware store and pick up 6 10mm, 1.50 x 40mm bolts, 6 m10 hext nuts, 12 10mm washers to go on each side, and 6 lock washers to make it a lil easier on you when your tightening!
Hope that helps
-Baum
Hope that helps
-Baum
Originally Posted by Moodist
I have Comptech Headers and I have the extra noise of air rushing, etc. I think it is just the nature of higher flowing aftermarket headers.
The noise you describe is exactly what I noticed once I installed my set of XS headers. After investigating a bit, I just think it's normal. I could not find any exhaust leaks.
BTW, I have 10 mm bolts installed on my set - I still get the whoosh sound.
Originally Posted by Sun Diego CL-S
aren't there DC headers for our car? i know if i had to do it again and had to go cheap, i would do DC.
Comptechs are the best and from what I've heard the XS ones are not too bad. I've heard that the DC headers for the CL sucks ass.
Back to a MT!
I guess its most noticable when Im driving next to walls, I figured there would be some added noise, just not that much (that isn't the great exhaust note!)....if there is anyone in the Orlando area with headers that would mind letting me hear their car...that would be great! I used the 6mm bolt, but I lined up the flanges perfectly, so it shoudlnt' matter. A 7mm, 1/4" drive socket is the excat size of the holes, so I put in one bolt, slid in the socket extension in another and used a screw driver in the third hole for perfect alignment and then tightened. I guess I will drive around for a while and see if there are any carbon build ups from an exhaust leak around any of the points of connection. If not....Its the sound they make and I will just learn to love it!!
Again, same thing here, sounds weird driving by stationary objects, but if I park the car, open the door and listen, there's no leak or odd hissing noice detected. Post an update if you hear anyone's from the outside. I'm going to see if my buddy can do a driveby for me so I can hear it first hand soon and do the same.
Advance
Get a stethoscope and run it around the entire exhaust to pinpoint a leak.
http://www.amazon.com/Wilmar-Automot.../dp/B0002KO39W
I'm here in spirit...
Originally Posted by RaviNJCLs
No you won't.
You couldn't pay me to put DC's on a CL.
ABP CL-S 6 NAV
hopefully DC redesigns their headers properly to fix the problem like exellerate said they would and make em compatible with the 6speeds.
But as of right now....... DC does suck ass on our CLs
Moderator Alumnus
Are you guys just talking about the DC fitment issues on 6-speeds or on A/Ts too? I almost considered buying the DCs instead since I loved the DC header I had on my EP3.
Still @ that avatar!
DiamondJoeQuimby
09-10-2015 11:40 AM
Hau_nguyen91
09-06-2015 12:53 PM
