flashing check engine light
Old Aug 2, 2004 | 12:24 PM
rbf351's Avatar
Registered User
to start i have an 03 6 speed CL-S
the other day it was wet out and was in 1st gear and floored the car(foot off the cluthc pedal) cause had massive wheel hop. then while the car was bouncing the check engine light started to flash. i let of the gas pedal and it stopped. check for codes and had none.
did the same thing this morning on dry land(made the tires break loose in 1st gear) check engine light start to flash
anyone else have this happen?
Old Aug 2, 2004 | 01:53 PM
scalbert's Avatar
Normal, the ECU just picked up soem random misfires due to the wheel hop and was just letting you know. It is fine and will happen on occasion.
Old Aug 2, 2004 | 01:55 PM
rbf351's Avatar
Registered User
it's happened a bunch of times and figured it was cause of the wheel hop, but never had it happen in my old car which had worse wheel hop than this car does
Old Aug 2, 2004 | 02:22 PM
ghost_masterCL's Avatar
misfires caused by wheel hop? how does that work?
Old Aug 2, 2004 | 02:38 PM
scalbert's Avatar
Excessive jarring on the engine. It may not be actual misfire but rather the ECU interpreting it as such.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
