The Final Thread over this...
Old Jul 4, 2005 | 07:44 PM
Cocoa's Avatar
2600lb CL
Exclamation The Final Thread over this...
I did some research over the actuator, and found that some of the S/C guys prefer to have their actuator disconnected to prevent knocking.
I've also read that it is powered from an electric motor.
So my question is, what should those running on nitrous do? Have it disconnected or have it working properly? Also, since it's an electric motor that keeps it functioning, is it just attached to the manifold with 2-3 bolts? Is it easy to replace yourself? Or is there more to it than I'm reading/seeing from pics. I'll soon have the Type S head in my car, and want to familiarize myself with the common problems that occur in the CLS cars. If mine isn't working, I'd like to install a new one. Is it as easy as that? Thanks in advance.
Old Jul 4, 2005 | 08:03 PM
mrsteve's Avatar
It is a very easy part to replace and very inexpensive (around $100). Not sure on the N2O question though. I believe Mattg (ran a 75 shot) left his connected. Also, you don't need to physically remove the motor to disable this feature. All that is needed is to disconnect the wiring harness. No DTC is stored, no CEL, etc.
Old Jan 19, 2006 | 05:07 PM
Cocoa's Avatar
2600lb CL
Back from the dead, I know.....
But just curious on how everyone else on nitrous goes about in this situation.
Keep the IMRC plugged, or unplugged....?
Old Jan 19, 2006 | 05:19 PM
power3dfx's Avatar
Parting out 02 Type S :(
the reason anyone disconnects the imrc is for detonation. i was detonating the other night (esm is back in the car, no emanage to retard timing) and i tried disconnecting it. i read another 1 lb boost (due to less volume) and the detonation was pretty much gone!
So your solution: you should leave it connected unless you hear detonation.
mitchigan
May 29, 2019 06:53 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
SUPRMN84
Oct 7, 2015 09:46 PM
c1souk
Sep 28, 2015 11:20 AM
STL TL-S
Sep 23, 2015 08:52 PM
