engine stalled, what could it be?
Old Oct 16, 2002 | 12:26 PM
sts's Avatar
sts
i'm in traffic this morning and as soon as i slow down to a stop the idle drops and the engine cuts off. no check engine or any lights come on. what's going on? it happened twice. a couple of times i've noticed that when i start the engine it doesn't catch right away. its not a smooth start up. could it be the timing, spark plugs, fuel injector, what?
Old Oct 16, 2002 | 12:54 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
take it to the dealer.. NOW!
Old Oct 16, 2002 | 01:02 PM
scalbert's Avatar
If it is driving fine otherwise it is most likely the IAC valve.
Old Oct 16, 2002 | 01:13 PM
Bill Faure's Avatar
I hate stuff like that. About 6 months ago during the work week I went out to lunch by myself. When I finish and go to head back to work my CLS would not start. It would turn over and turn over, but no fire/spark. After about 8 to 10 attempts I pulled the key out of the ignition and waited a minute or two. Put the key back in and it fired right up as usual. Since that happened I have not seen this phenomenon reappear! Strange!
Old Oct 16, 2002 | 01:41 PM
Redpaste's Avatar
Jumping Ship
Take it to the dealer. My guess is the starter, alternator or if your really screwed exhaust manifold. My $.02. but good luck anyways
Old Oct 16, 2002 | 01:46 PM
sts's Avatar
sts
unfortunately my warranty has expired. i took a drive about an hour ago to see if it would happen again. started up fine and drove around for 10 min.... nothing. what's the IAC valve?
Old Oct 16, 2002 | 02:07 PM
O-Town_TypeS's Avatar
S2000 Owner
This happens to me sometimes. I told the dealer about it and of course they cannot reproduce it. There is a TSB about the fuel pressure regulator. I asked them about that and they said it was not for the problem I was describing. So now I just have to deal with it.
Old Oct 16, 2002 | 02:12 PM
oonowindoo's Avatar
every morning when i start the engine. it sounds like it s gonna stall... but never did ( that s when the engine is cold)
Old Oct 16, 2002 | 02:13 PM
scalbert's Avatar
Idle Air Control Valve, it controls the idle when at a low engine speed with the throttle closed. When cloged or failing the car usually shows similar symtoms.
Old Oct 16, 2002 | 02:16 PM
sts's Avatar
sts
cool! thanks all, for helping. btw where is the IAC valve located?
Old Oct 16, 2002 | 02:19 PM
scalbert's Avatar
At the base of the throttle body. You could pull it off and spray carb cleaner into the passeges and then re-install it. This might help with little to no expense.
Old Oct 16, 2002 | 02:22 PM
Happy CL-S Pilot
You are out of warranty, have problem, so order for yourself a HELMS service manual.
Okay!
Old Oct 16, 2002 | 02:26 PM
Pappy's Avatar
Do it! U Only Live Once!
When was the last time you changed the fuel filter?
Old Oct 16, 2002 | 04:25 PM
dbox's Avatar
whoXwanXsum
fuckn weird! same exact thing happen to be about a week ago! i really love my car i just wish more quality went into the MAKING of it
Old Oct 16, 2002 | 05:19 PM
Mike's Avatar
STS, I have the Helms manual if you'd like to borrow it. PM me or call me on my cell.
Old Oct 16, 2002 | 10:16 PM
beestea's Avatar
My car did this (stall) two or three times with in the first year of owning the car... then it never happend again. Its been at least a year since it did that.
Old Oct 16, 2002 | 10:22 PM
mattg's Avatar
fuel pressure regulator. it's a tsb, they already replaced mine.
Old Oct 16, 2002 | 11:15 PM
sts's Avatar
sts
do you have the tsb #?
Old Oct 16, 2002 | 11:23 PM
GOT PSI?'s Avatar
It's Go-Time.
One of the local Vancouver guys had the same problem, and I think a TSB issued for that., I think.
Old Oct 17, 2002 | 12:22 AM
Roleez's Avatar
idling problem
Been a member for a while, but never posted anything till now. Thought this would be extremely helpful to those CL owners that ever had their car stall on them at a stop OR ever had a problem where the idle surges between 1000-2500rpm at a stop. Here's the problem: a defective binding air control valve on the throttle body. The entire throttle body was replaced (P/N 16400-PGE-A11). It was the cause of the above problems on my '03 6-spd when it had ~4000 miles on it. Dealer couldn't find the problem b/c the C/E (Check Engine) light didn't light at that time. Problem never came back till 7000 miles later. This time the C/E light came on. Fixed under warranty. Problem never came back.
Old Oct 17, 2002 | 12:25 AM
mattg's Avatar
item # 617703
service bulletin # 01001
seq. # 176
Old Oct 17, 2002 | 12:48 AM
Yumcha's Avatar
I had this problem too where my car stalls when it slows down and comes to a stop. It happened to me about 8 times although the dealership could not reproduce it. It drove me nuts...
Anyhow, as luck would have it, they cleaned out a filter of some sort for my fuel injection (I THINK) and everything's been fine ever since. I hope it all works out for ya! Good luck.
Old Oct 17, 2002 | 02:21 AM
sts's Avatar
sts
item # 617703
seq. # 176
thanks!
Old Oct 17, 2002 | 02:27 AM
mattg's Avatar
http://www.nhtsa.dot.gov/cars/problems/tsb/index.cfm
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
