DYNO setup for Dec 11th at 2:30~pm for OBX Headers!
Old Dec 3, 2002 | 12:12 PM
SilverBullet_RENAMED's Avatar
I just got my scheduled dyno run in. I dynoed before the headers 199.9 and 182 tq. With we will see!!!
Old Dec 3, 2002 | 12:52 PM
swt-cls's Avatar
Sup man! Where u havin the dyno done at? If its in San Antonio I might join ya. Let me know man
Old Dec 3, 2002 | 12:57 PM
San Antonio. I plan to get there by 2:30 which is my apointment, but I have a doctors apointment right before that so I might get there earlier or later. Defintely not later I am sure, most likely earlier.
It's at Team Xtreme. And if you want to dyno you need to schedule yourself with them as well.
Old Dec 3, 2002 | 01:03 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
SillverBullet,
Could you post your dyno graph?
Old Dec 3, 2002 | 01:07 PM
Originally posted by Nashua_Night_Hawk
SillverBullet,
The stock one? I don't have the header one done yet. Thats Dec 11th.
Here is Stock graph:
Old Dec 3, 2002 | 01:13 PM
jimcol711's Avatar
it PAINS me to see a stock CL-S dyno below 200 hp....but the OBX headers will have taken care of that....i think your dyno, silverbullet, will be a dyno that no one will be able to dispute like everyone whose been bashing on Nashua's because of his low stock numbers or his pullies, etc...
Old Dec 3, 2002 | 01:14 PM
Happy CL-S Pilot
I would guess that you would run at least 190 lbft of Torque from 3000 rpm all the way to 6500 rpm... you should top at 225 WHP!
And I also assume that you head HKS exhaust on the stock dyno....
Old Dec 3, 2002 | 01:18 PM
Rod's Avatar
Rod
On this forum? There will always be something to dispute....like how his dyno with headers will probably be in much cooler weather, etc., etc. But it will be nice to finally see another dyno of the OBX headers.
Old Dec 3, 2002 | 01:20 PM
I agree. But most dyno stock below 200 . I have not changed a thing on my car since the last dyno. I actually wasn't even running my IK20s on the last dyno and still are not. Been running the stock NGK plugs. I wanted to make sure nothing changed on the car between the last dyno run and this one for accurate results. Also letting the ECU learn the extra power of the headers so it will give real results.
I hope to see 225-230 hp at least. And at least 195 TQ!
Old Dec 3, 2002 | 01:22 PM
Yeah, but that would be useless, because the Dyno adjusts for the temp, but also it was 50~ degrees on the last dyno I did. And today its 75. So that day next week it might be around 50~ I am hoping.
Happy CL-S Pilot
If you can record engine coolant temprature and weather stats that would be great too.
Old Dec 3, 2002 | 01:24 PM
Weather no problem, but how do I check the engine coolant temp?
Old Dec 3, 2002 | 05:17 PM
EricL's Avatar
OBD II scan tool with the appropriate features would be needed for the ECT (engine coolant temperature). It is also possible to patch into the back of the connectors on the PCM/ECU, but that is not the "easy" way (and you would need to convert the voltage to temperature)...
Old Dec 3, 2002 | 06:45 PM
Well then I guess that test won't happen. Doh.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
dirleton
Sep 25, 2015 12:25 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
