Driver's side window is "sticking" on hot days
Old May 27, 2004 | 06:21 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
Is anyone else having this problem...if so what can I do about it? On really hot days when I try 2 use the auto down feature, the window stops and I have to hit the button a couple more times to get it down.
Old May 28, 2004 | 11:08 AM
Doom878's Avatar
Bad regulator?
Old May 28, 2004 | 11:16 AM
DarkSithCL's Avatar
Could be...maybe when it gets too warm...only got 37K on the CLS...need to take it to the dealer maybe...thanks for the reply Doom878!!!!
Old May 28, 2004 | 11:59 AM
CLpower's Avatar
teh Senior Instigator
get some of hondas silicone spray and spray it in the crevices
Old May 28, 2004 | 12:00 PM
tankmonkey's Avatar
6 speed...
my car has the same issue. it only happens with the interior gets warm from the sun ('bout that time of year again).
prolly should have it looked at, but I'm too lazy.
Old May 28, 2004 | 12:05 PM
Doom878's Avatar
Let me know because it gets hot out here too. I haven't had this problem but I did have to replace my regulator on my side. It wouldn't close all the way.
Old May 28, 2004 | 08:06 PM
DarkSithCL's Avatar
I rally appreciate the info...For the time being...I'll try the silicone..thn have them look @ it next month when I get the oil changed....
Old May 28, 2004 | 11:49 PM
Nicky Pass's Avatar
Fuct in the hed!
Its probably the rubber heating up and actually kind of sticking to the window....when you roll down the window you break that temporary seal
Old May 29, 2004 | 01:37 AM
Ant7701's Avatar
Sweet as Gold
It's normal...about the only thing you could do is replace the window run channel...but it will happen again!!so if it really bothers u...spray some silicone spray inside the run channel and move the window up and down to lubricate it.
Old May 29, 2004 | 11:09 AM
DarkSithCL's Avatar
So the window is stopping because when it sticks the motor stops, so it keeps from damaging the whole mechanism I quess...OK, I understand what to do now
Old May 29, 2004 | 02:58 PM
Ant7701's Avatar
Sweet as Gold
the motor doesn't stop it...the auto-down feature is controled by a small unit. It's a safety feature that stops the motor from moving down just ncase u might be crushing something or whatever. Just lube up the run channel so it doesn't become so sticcky when it gets hot.
Old May 29, 2004 | 03:01 PM
tmk70's Avatar
Masshole
Old and very well known problem...you just have to deal with it.
Old May 30, 2004 | 02:04 PM
madj80's Avatar
I agree with CLpower, get some silicon spray. The same thing happened with my old CRX. If you don't lube the edges ever now and then it will cause bigger problems in the long run.
Old May 30, 2004 | 03:18 PM
einsatz's Avatar
I miss my 03 CL-S :(
The pass. side window of my CL used to stutter going down on hot days. The silicone should do the trick.
jblessing
Aug 8, 2018 09:43 PM
acura_dipset_tl
Jan 1, 2016 03:02 PM
PortlandRL
Sep 14, 2015 12:01 PM
kuzdu
Sep 10, 2015 08:42 PM
ahsm
Sep 9, 2015 08:35 AM
