DIY: Hood Pin Install
as far as i know, no diy for this. so im making one.
hood pins are made by and from aerocatch. they are the carbon fiber look, locking plus flush hood pins.
now for this u will need:
-drill bits from 1/8" all the way up to about 5/8". (and or a uni bit (do not use uni bit on cf hood, it will start the rip the hood instead of cutting it))
-dermal
-safety glasses or face shield (optional but highly recommended)
-some sort of mask (optional but recommended)
-some sort of die, i used red lock tight.
-tape measure
-painters tape (optional but highly recommended)
-sand paper (80-120 grit (one of those or something in between) paper)
-allen keys
-screw drivers
-marker or pencil
will update with more tools as the project moves along
get started with the pics and steps
the kit
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0255.jpg)
1.put the painters tape on the hood to reduce scratching
2.measure and mark the hole on the bulk head to where u want the hood pin to sit.
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0259.jpg)
3.start drilling with a small bit (1/8") aka making a pilot hole.
then start moving up with the bits or use a uni bit. made mine 7/16" (some free play)
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0261.jpg)
4.test fit rod.
5.now, mark the top of the rod. i used red thread sealant and it worked out great.
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0264.jpg)
6.find the mark on the hood
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0269.jpg)
7.drill a small pilot hole on the hood (this was hard for me to do, bc i love the hood so much)
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0271.jpg)
8.i went up the drill bits by a (1/8" each bit). if u go up to fast the bit will catch and could crack the cf hood. do this slowly and with the weight of the drill.
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0273.jpg)
9. insert rod and close hood slowly
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0275.jpg)
10 (optional) i cut some of the fg on the bottom so the rubber stopper has more contact area
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0279.jpg)
gonna finish up tomorrow. thats when the major cutting on the hood happens.
-dermal
-tape measure
-allen keys
-screw drivers
-marker or pencil
the kit
4.test fit rod.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I Wanna Beer
Carbon fiber hoods are generally known for having poor hood latches. In many cases the latches don't hold and the hood either flys off or it flips up and smashes the windshield. Because of this many people install hood pins. Some CF hoods don't even come with latches and require the use of hood pins.
The TARDIS is my
Whats up with RDX owners?
Be VERY careful dremelling out the rest of the hood.
finished up today. still have to cut the bulk head cover so it matches up.
extra tool
roto zip- made cutting the hood so much neater and faster and easier
wenchs or sockets with ratchet
11.place hood pin where u want it and trace around it (the smaller part, not the outside)
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0280.jpg)
12.traced
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0284.jpg)
13. i used my roto zip to cut the hole, makes it easy and fast. cut the hole smaller than what u want it to be then make necessary cuts until it fits snugly
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0290.jpg)
dont forget about the under side of the hood
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0288.jpg)
14.test fit latch
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0292.jpg)
15. drill the mounting holes (start small and work your way up the bits by 1/8" increments)
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0296.jpg)
16. for the bottom side u will need to make the holes bigger so a socket can fit in, i used my roto zip. was easy, accurate, and fast
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0297.jpg)
17.peel off the tape and inspect work
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0299.jpg)
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0301.jpg)
18.tighten with the supplied allen key bolts and nylon locking washers
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0303.jpg)
18.makes sure it operates freely
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0306.jpg)
19. close hood to make sure pin slides in freely and the latch catches it and closes
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0308.jpg)
20.inspect work, tighten all bolts to make sure none are lose.
and stand back and look at your work
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0309.jpg)
extra tool
12.traced
14.test fit latch
![](http://i252.photobucket.com/albums/hh9/trviper03/03%20CL-S6/hood%20pin%20install/DSC_0314.jpg)
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
BoricuaTL
04-08-2016 01:08 PM
asahrts
09-04-2015 05:55 PM
