DEPRESSED!!! 221WHP with SUPERCHARGER!!!???!!!
Old 09-28-2007, 01:16 PM
  #281
Advance
gc86's Avatar
Give us a update, have you installed the new plugs yet?
Old 09-28-2007, 01:42 PM
  #282
4drs just wanna have fun!
Accord_V6_400m's Avatar
Originally Posted by New Image
got my fuel pressure gauge installed. idle fuel pressure is 28~30psi. wot pegs out at 100
Someone correct me on my figures if im wrong but I thought on vacuum the pressure was supposed to be high 30's and off vacuum about 60psi. Also, is it not more desirable to have lower FP at WOT when possible, possibly by using a 1:1 FPR?
Old 09-28-2007, 01:46 PM
  #283
B A N N E D
New Image's Avatar
pim waiting for the motor to cool off so i can pull of the blower and install the plugs
Old 09-28-2007, 04:17 PM
  #284
THE J35A2...
SIRSIG's Avatar
get the FP up to 38-40psi at idle, then make some adjustment from there if necessary...
Old 09-28-2007, 04:19 PM
  #285
B A N N E D
New Image's Avatar
i just took out the plugs and the rear valve cover. the rubber o ring gasket around the plug was torn leaking oil onto the plug. one of the other plugs tip was broken. i dont know how i never noticed this b4.
RANDOM MISFIRE???!!!!
Old 09-28-2007, 05:17 PM
  #286
THE J35A2...
SIRSIG's Avatar
may god save your car...
Old 09-28-2007, 08:07 PM
  #287
B A N N E D
New Image's Avatar
ok, i adjusted my fuel pressure. with the car on and idling its at 40psi, with it off with ignition on it is at 50psi. which way do i adjust, with the car on or off?
Old 09-28-2007, 10:52 PM
  #288
horsepowercrzy18's Avatar
hey
adjust with car off i believe
Old 09-29-2007, 01:16 AM
  #289
Blown is Best
Allout's Avatar
There is no rubber O-Ring gasket on the plugs.
Old 09-29-2007, 01:17 AM
  #290
Blown is Best
Allout's Avatar
Old 09-29-2007, 01:50 AM
  #291
I think the gasket he was refering to was the one in the valve cover
I love that running smiley
So anyone else curious as to why they dont have double Iridium plugs? Or the new Accord dual probe plugs? (ground electrode looks like center electrode)
Old 09-29-2007, 02:44 AM
  #292
B A N N E D
New Image's Avatar
on the valve cover where the coil goes there is. thats what i meant
Old 09-29-2007, 02:46 AM
  #293
B A N N E D
New Image's Avatar
back to fuel pressure, set with car on and idling or with car off and ignition on?
Old 09-30-2007, 10:55 AM
  #294
B A N N E D
New Image's Avatar
Old 09-30-2007, 11:19 AM
  #295
mrsteve's Avatar
Obviously you need to do it with your car on.
No accessories running.
Old 09-30-2007, 12:49 PM
  #296
B A N N E D
New Image's Avatar
ok, ive been fiddling with the fuel pressure, and it seems no matter what psi i set it to, anywhere from 25 to 40 psi at idle, the car still runs rich. why is that?
Old 09-30-2007, 11:02 PM
  #297
Advance
gc86's Avatar
so cars not missfiring anymore with the new plugs? problem solved now we're dealing with FPR?
Old 10-01-2007, 09:53 AM
  #298
mrsteve's Avatar
How do you know the car is running rich? Unless you are throwing P0175 codes you aren't too rich.
Your AFR should be deep in the 11s most of the time while you're running wide open.
Old 10-01-2007, 10:31 AM
  #299
B A N N E D
New Image's Avatar
my afr is low 10s at wot, even 10 flat, and on partial throttle its in the 11s
Old 10-01-2007, 12:06 PM
  #300
CleanCL's Avatar
IMO that means very little since there is a possibility that the gauge is either not hooked up correctly or malfunctioning. you need to bring the car into a professional with the blower OFF THE CAR and get it running right.
btw - mrsteve greatest avatars ever. i loved the NOT YOURS - YOURS one too. =]
Old 10-01-2007, 01:11 PM
  #301
B A N N E D
New Image's Avatar
its an aem wideband, theres nothing to hookup wrong. bu anywho, im going to take it to jotech motorsports and let them figure it out.
Old 10-01-2007, 01:21 PM
  #302
'08 MX5 GT 6spd.
MarbleGT's Avatar
Received 1,192 Likes on 485 Posts
So when/if you ever get this car working right...do you plan on ragging on it and driving crazy like the last one?....i'm gonna go with yes.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/itOQTF7DXUU"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/itOQTF7DXUU" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/D_3-zVPPY3c"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/D_3-zVPPY3c" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/f1jcV9awUfo"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/f1jcV9awUfo" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/_44JO4edlUA"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/_44JO4edlUA" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/j9xNiKaeZ3U"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/j9xNiKaeZ3U" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Old 10-01-2007, 01:23 PM
  #303
'08 MX5 GT 6spd.
MarbleGT's Avatar
so when/if you ever get your car working properly, are you going to continue to rag on it and post videos on Youtube?
http://youtube.com/watch?v=j9xNiKaeZ3U
http://youtube.com/watch?v=_44JO4edlUA
http://youtube.com/watch?v=kZr7W-GBvD4
http://youtube.com/watch?v=D_3-zVPPY3c
http://youtube.com/watch?v=itOQTF7DXUU
Old 10-01-2007, 02:54 PM
  #304
fuzzy02CLS's Avatar
Guys need to get off this driving kick. I don't consider any of that ragging on a car with 300+ supercharged horses.
Old 10-01-2007, 07:31 PM
  #305
mrsteve's Avatar
What is your static fuel pressure?
Old 10-01-2007, 11:02 PM
  #306
'08 MX5 GT 6spd.
MarbleGT's Avatar
Originally Posted by fuzzy02CLS
Guys need to get off this driving kick. I don't consider any of that ragging on a car with 221 supercharged horses.
fixed.
Old 10-01-2007, 11:30 PM
  #307
Beware of leakage
Chopsie's Avatar
I'll see your depression and raise you a new car.
Glad to see your trying to sort out your problem though.. With tearing everything apart let us know if you find Jimmy Hoffa's finger or Monica Lewinsky's semen sponge.
Old 10-02-2007, 07:23 PM
  #308
mrsteve's Avatar
Old 10-03-2007, 10:27 AM
  #309
B A N N E D
New Image's Avatar
right now at idle 20 psi, but im still running rich as shit
Old 10-03-2007, 12:01 PM
  #310
mrsteve's Avatar
If your static fuel pressure was 20psi your car would stall.
Old 10-03-2007, 04:05 PM
  #311
BlackV62K2's Avatar
Set your fuel pressure @ idle (warmed up car) to 38-40psi with VAC connected. There's no way you can be running @ 20psi @ idle.
Old 10-03-2007, 06:38 PM
  #312
B A N N E D
New Image's Avatar
should the gauge read any pressure with the car off? my gauge reads about 10psi with car off
Old 10-03-2007, 08:40 PM
  #313
mrsteve's Avatar
Doesn't matter what it says when the car is off.
What gauge do you have?
Old 10-03-2007, 10:04 PM
  #314
B A N N E D
New Image's Avatar
its an ac autotechnic mechanical.
i just set my fpr to 38psi and im not messing with it anymore
Old 10-03-2007, 10:59 PM
  #315
Blown is Best
Allout's Avatar
How's the AFR with the FPR set at 38?
Old 10-04-2007, 10:23 AM
  #316
B A N N E D
New Image's Avatar
its pretty much the same. very rich on wot, stoich on idle and cruise. but with the fpr that high my car stalls when i drop it into neutral
Old 10-04-2007, 11:46 PM
  #317
Blown is Best
Allout's Avatar
The stalling going into neutral could be a vacume leak.
Old 10-05-2007, 01:45 AM
  #318
mrsteve's Avatar
Please tell me the gauge isn't mounted inside the cabin.
38psi static? You should be adjusting your static fuel pressure. Not in vacuum.
Old 10-05-2007, 01:47 AM
  #319
mrsteve's Avatar
I don't want to sound rude, but it has become quite obvious that the issues you are having with your car are beyond your knowledge. I'd seek professional help.
Old 10-05-2007, 01:52 AM
  #320
mrsteve's Avatar
Okay then it is an airflow problem. If the car was too rich you would be storing P0175s. Clearly it isn't too rich in closed loop so I don't think fuel is the problem. If the car stalls while going in to neutral it could very well be a IAC valve problem.
Did you ever purchase the scan tool? The ScanGaugeII is a good product that will display everything you need.
Quick Reply: DEPRESSED!!! 221WHP with SUPERCHARGER!!!???!!!
