Car Shakes between 50-55 mph
Old Apr 5, 2006 | 03:03 PM
sham's Avatar
My car drives smoothly except for when I'm between 50 and 55 mph. Its a pretty noticable shaking of the car (you can feel it in the pedals and see the steering wheel shake). Passengers notice it too. I have the tires rotated and balanced, and the alignment has also been done in the last 2 weeks. Yet I still have the shaking. Any idea what could be the problem? I have done plenty of WOT's in my day, as well as some E-Braking. Could that be the reason? Thanks.
Old Apr 5, 2006 | 03:46 PM
us000011's Avatar
Old&CnL
I had this problem with my Legend- it's CV joints; get them lubed, reworked or replaced. It will only get worse with time.
Old Apr 5, 2006 | 04:30 PM
sham's Avatar
Thanks. You have an idea of how much they run?
Old Apr 5, 2006 | 05:35 PM
mrsteve's Avatar
CV joints or a blown axle.
Old Apr 5, 2006 | 06:24 PM
sham's Avatar
if my axle was damaged, wouldn't i notice it at all speeds? the only time the car shakes is between 50-55,60 mph.
Old Apr 5, 2006 | 07:06 PM
quicksilver10101's Avatar
i have the same problem...only between 50-60....i got my tires balanced and it still did it someone told me it was my bent rim but i find it weird that its only at that speed.
Old Apr 5, 2006 | 07:12 PM
sham's Avatar
have you replaced the rim? if so does it still shake. my rims don't look noticeably bent, but i have hit curbs and potholes before.
Old Apr 5, 2006 | 07:24 PM
o1s's Avatar
o1s
mine shook pretty bad between 50-60 mph. it was outter cv joint on the passenger side.
Old Apr 5, 2006 | 07:59 PM
Nitz's Avatar
Check the previously mentioned things but if you've been doing some serious e-braking then you may have some flat spots in the tires. I had worn some flat spots in the back tires having some parking lot fun and I never noticed I wore flat spots in the tires due to the stiff suspension on my Accord. But, when I gave the rims/tires to my cousing for a stock suspension those things thumped as they turned around. Just something to check...
P.S. Video of some parking lot fun in my old Accord...
AVI format -10.33 MegsClick here for Video
Mpeg Format -23.26 Megs Click here to d/l vid in mpeg
Old Apr 5, 2006 | 08:56 PM
'01White3.2CL's Avatar
TellinItLikeItIsSince1/06
Dunno if this is exactly the same as with you guys, but when I get up to 50-65 m.p.h., the car is smooth. It's only under light braking (or heavy also) that the whole car shakes. The steering wheel shakes the most. What's wrong with our cars?? seems like a common problem...
Old Apr 5, 2006 | 10:17 PM
CL FWD SPEED's Avatar
What to do, what to think
warped brake rotors?
Old Apr 5, 2006 | 10:50 PM
sham's Avatar
haha i have that same problem when i brake. my brake pads had 20% of their life left on them, yet the rotors were warped. i have new pads now, but the same rotors. thats what i get for being a college kid that can't afford the maintenance on his car.
Old Apr 5, 2006 | 10:56 PM
ktgumbo's Avatar
Balla on a Budget
Would a messed up axel be replaced under warranty if the car is lowered on Comptech Springs? I am thinking no
Old Apr 5, 2006 | 11:31 PM
sham's Avatar
According to what i read in the 'similar threads' thing at the bottome of the screen, i think i narrowed it down to CV Joints and motor mounts. i'm gonna guess its the CV joints bc every once in a blue moon my car will squeal like a stuck pig when i'm in a parking lot making slow turns. the dealer said they will replace both of them for $350 if I understood her right.
Old Apr 6, 2006 | 02:20 PM
Bobbydoedoe's Avatar
I'm Cool
my sis's tsx has the same problem, and it cause was 2 bent rims. So that might be the cause for your case
Old May 3, 2006 | 10:01 PM
sham's Avatar
Ok, I was wrong. My front two rims are both bent. So that is the cause of the awful shaking. Discount Tire Company (my tire people) say they can order 2 factory rims just like mine from their warehouse for $100 each. So basically that will come out to $240ish after shipping. Seems too good to be true.
Old May 3, 2006 | 10:14 PM
mrsteve's Avatar
How the hell did they balance your wheels without figuring out you had two bent wheels?
Old May 4, 2006 | 09:31 AM
sham's Avatar
I'm not sure really. I do know I have to get new tires now because they wore down in a weird way bc of the bent rims. But I'm happy bc at least now I know nothing serious is wrong with my car.
Old May 4, 2006 | 01:56 PM
nitelyfe's Avatar
You underdig?
How is your diag goin now? I was doin a search on here for other shit, found your post and thought I could drop some knowledge.
I had what I think is the same problem only mine started at about 40mph and stoped at about 55. I took the bitch to 2 acura dealers after I took it to my mechanic who coouldn't find what was wrong and they just dicked with me and charged $125 to do so.
I then, recently, took it to a Honda dealer. I explained them what was up and they found that my right side drive assembly was the problem BUT, only under load. When it was on the lift it looked fine. They replaced my right side drive assembly and $900 later, I have my baby back. Rides smoth as silk now. Cost a lot but, the dope ass feeling of driving a working Type S is worth it.
P.S. I also thought it was motor mounts so I replaced each one myself at a reasonable cost but, it didn't fix the problem. Oh well, needed to be done anyway.
Old May 4, 2006 | 02:00 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
For me..it was my cv axles 45-60 or under heavy load....rim vibrations usually occur at about 80mph....bent rim...they should have seen it when they mounted your tires and couldnt balance it.
Old May 4, 2006 | 02:10 PM
DutchCLS's Avatar
01 CLS
a bent rim can be very minor and over looked by the tire installer. And balancing a tire in the air can hide the flat spot on the rim very well when balanced. I had the same issue, had my tires balanced three times with no change, was not until a had a rims refinished that the flat spot showed up. Once that was corrected car rode nice and smooth. I'm not saying you have a bent rim but just keep it in mind if all else fails.
Old May 4, 2006 | 02:17 PM
nitelyfe's Avatar
You underdig?
I should have added that I also had 1 bent rim. None of the mechanics I took my car to for this found the bent rim and my tires were balanced 3 times during this fucked up adventure. It wasn't until I jacked the front of my car up and ran the engine to 45 that I noticed the rim wobble. Scary shit but, it had to be done.
BUT... my rim was still bent and moved to the back of my car after the drive shaft assembly was replaced and I couldn't even feel it. It has been replaced since.
My guess is you have a combo of problems like I did but, hopefully you find a cheaper fix than I did.
Old May 4, 2006 | 03:25 PM
sham's Avatar
I think I'm gonna buy 4 new rims and 3 new tires (one tire was already replaced 2 weeks ago). I am thinking about getting 18" on the back and 17" on the front? I tried to search the forums to see if someone else has tried it, but I came up empty. If I can't find any pictures of such a thing, I'll prolly just get 4 17" rims.
Old May 11, 2006 | 01:15 AM
reLaxin12's Avatar
'01 CL-S
I just bought a 01 CLS and I had that same problem. When I took it back to the dealer they found out that 3 of the wheels were bent. Don't ask me how that happens, but since I just bought the car they decided to replace all the wheels for me. This is probably the problem.
Old May 12, 2006 | 03:19 PM
sham's Avatar
I've had the car since 03, so I'm sure I'm responsible for the damage. I got a flat 2 nights ago too, so I'm driving on a spare for the next few days. No reason to put a new tire on a bent rim. I'm going to replace everything sometime in the next week. I'm excited. I'm going to get some basic 17" rims, nothing flashy.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Legend2TL
Motorsports News
Jan 31, 2016 09:27 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
