Can 12V outlets be switched to always on?
Old Nov 24, 2006 | 07:54 AM
fuzzy02CLS's Avatar
On an old car I had I could take out a fuse & that would make the 12V outlets always on even if the car was off.
Is that possible in the CL?
I see no mention of it anywhere in he service manual.
Any way to mod the outlets so they are always powered?
I need a way to keep power to my emergency lights when I turn the car off.
Old Nov 24, 2006 | 09:09 AM
dwest1023's Avatar
You will just have to rewire the outlet. Just find the hot wire connected to the outlet and wire it to a contstant 12V source. You might want to intall an inline fuse while you are add it. Not a very hard thing to do
Old Nov 24, 2006 | 09:11 AM
vincethe1's Avatar
3.2 VTEC
it's possible, you just gotta run a jumper wire in the fuse box, not sure exactly which fuse it is since i hadn't bothered doing that but look for it, it's gotta be called the accesory power outlet fuse or something like that.
Old Oct 28, 2007 | 04:54 AM
rp_guy's Avatar
'03 ABP YA4-S 6MT
did you ever do this ? i want to wire one/both of them to be always on.
Old Oct 28, 2007 | 11:30 AM
mrsteve's Avatar
Panel beneath the drivers side dash. Panel faces in towards the driver.
Old Oct 28, 2007 | 11:51 AM
JohnBlayz142's Avatar
Keeping the Stealth alive
These guys are right, and another way you could do it would be to run some 4 or 8 gauge audio wire to the back. You could then put the appropriate plug ins on the end or even an inverter...if you don't need anything more than a 12V outlet this may be a bit much though.
Old Oct 28, 2007 | 12:59 PM
mrsteve's Avatar
Why would you need 4 or 8 gauge?
He's only running emergency lights.
Old Oct 28, 2007 | 03:48 PM
See the last sentence of my post.
What exactly are "emergency lights"?
Old Oct 28, 2007 | 04:56 PM
fuzzy02CLS's Avatar
Search my friend. In any case they are not on my car anymore. I'm done with it.
I never got around to doing this. Never had the time to mess with it.
Old Nov 2, 2007 | 06:45 PM
Misdby1's Avatar
i've been meaning to do this also.
Old Nov 2, 2007 | 06:56 PM
TypeStylinOnU's Avatar
dont be mad
ahaha nice avatar
Mike Pilipenko
Mar 26, 2024 09:21 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
TL14
Sep 24, 2015 04:37 PM
eastcoastguy
Sep 23, 2015 06:29 AM
