blown shock??
Old Jan 6, 2004 | 03:31 PM
Pure Adrenaline's Avatar
Dragging knees in
blown shock??
Mods listed as below, and I noticed last night that my rear driver's corner is sitting about half an inch lower than the rear passenger side. Could it be a blown shock?? It's only been about 5000 miles since the drop.
Old Jan 6, 2004 | 03:39 PM
Slimey's Avatar
Where is my super sauce?
Is that corner bouncing all over the place? If you quickly push down on the corner does it bounce many times?
Any noise coming from that corner?
What does the shock look like? Is there oil dripping from it?
Old Jan 6, 2004 | 03:44 PM
Dragging knees in
I might take the wheel off and thoroughly search for any oil leaks, I guess.
It's not bouncy, really. I took a really hard right turn earlier today, and although I was sliding everywhere (9 degrees out, no traction), I didn't feel that corner bouncing much. But that might be because I was sliding.
I'm gonna go for a drive and see if it bounces now. Thanks for the tip.
Old Jan 6, 2004 | 03:46 PM
mattg's Avatar
actually, all cl-s sit like that. if you measured before the drop it would have been tha same way.
Old Jan 6, 2004 | 03:47 PM
Dragging knees in
Seriously?
Old Jan 6, 2004 | 03:48 PM
mattg's Avatar
yes. mine was the same way. the owner of the shop who installed my H&R race springs a couple years back had a tl-s, same thing w/ it. i noticed the difference and asked him about it. he said all the cl's and tl's he had ever worked on were the same. it's not a coincidence, it's how the unibody is put together.
Old Jan 6, 2004 | 03:50 PM
Dragging knees in
That's quite difficult for me to believe.
You mean to tell me that a TL-S (same thing) with an H&R Sport drop sits lower on one side than the other??
It used to be nearly even, and I know for sure because I check the width of the gaps often. And I only just found out that the left side rear is sitting lower than the other.
So if all CL/TL's sit like that, then what's the cause? Does anyone know? Is it just horrible weight distribution or what??
Old Jan 6, 2004 | 03:54 PM
mattg's Avatar
in the rear, yes. just like you said, drivers side sit's ~ 1/2" lower.
Old Jan 6, 2004 | 03:57 PM
Dragging knees in
Gotcha. Thanks a lot for the info. I feel like the 3.2L block has been lifted off my chest.
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
ripit
Sep 26, 2015 06:19 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
polish_pat
Sep 25, 2015 12:24 PM
STC
Sep 23, 2015 04:36 PM
