Before and After?
Old Mar 21, 2010 | 08:19 AM
  #441
MD03CL-S's Avatar
^^was there supposed to be red text?
Old Mar 21, 2010 | 10:55 AM
  #442
Rajca's Avatar
wham bam thank you ma'am
ur joking right?
Old Mar 21, 2010 | 11:53 AM
  #443
CLPimpin114's Avatar
Tokin up in
Originally Posted by TouringLow
hi, great build.
can you make a DIY: how to build a car please?
U Serious?? This build probably took more then a couple Thousands of $$ and a crap load of hours to build. No way a DIY can be made. Mayb a List, but even then theres been a lot of custom work done here. Outta luck man
Old Mar 21, 2010 | 12:18 PM
  #444
ThinJim's Avatar
Originally Posted by Rajca
what engine mods do u have done and how many psi are u gonna be boosting?
stock pistons/rods, stock sleeves, stock valves, springs, retainers, shocks off a 75 gremlin, tranny out of a 66 chevy.
couldn't resist myself. nothing has been left untouched on the inside of the motor. It will take whatever I throw at it. I will start conservatively on the boost and work my way up. I have many different ways to go and may even upgrade to a larger turbo at some point up the road. As in all high output motors, the head gasket is a problem, but not insurmountable as one may think.. this motor is "o" ringed both on the head and deck using a copper gasket.
What you don't see is what is on the inside...
Old Mar 21, 2010 | 07:43 PM
  #445
NSXNEXT's Avatar
hi, great build.
Old Mar 21, 2010 | 09:06 PM
  #446
civicdrivr's Avatar
Bwahahahahahaha, well played good sir
Old Mar 24, 2010 | 01:39 PM
  #447
RUF87's Avatar
Lead Footed
Oh soo sweet!!
The only sucking sound I've heard stronger than that was coming from our Congress and White House.
Ruf
Old Mar 24, 2010 | 02:07 PM
  #448
jproy's Avatar
MP90 uninstalled
I cant see the picture thinjim posted. It is a red X
Old Mar 24, 2010 | 02:44 PM
  #449
Jacobpockros's Avatar
I wanna see this thing race already. I'm guessing a 9 or lower in the 1/4 mile
Old Mar 24, 2010 | 03:16 PM
  #450
phee's Avatar
I got the Shifts
its gunna be hard putting down all that power in a FWD hawndah
Old Apr 7, 2010 | 06:27 PM
  #451
00suprchrgdAV6's Avatar
Didnt he fab it to be rwd?
Old Apr 7, 2010 | 06:33 PM
  #452
Rajca's Avatar
red txt= joking/ not serious
Old Apr 7, 2010 | 06:34 PM
  #453
civicdrivr's Avatar
Red text wins again!
Old Apr 7, 2010 | 07:07 PM
  #454
Old Apr 7, 2010 | 08:46 PM
  #455
fsttyms1's Avatar
Old Apr 8, 2010 | 03:12 PM
  #456
Silva-type-s's Avatar
Got your mom in
Old Apr 8, 2010 | 06:00 PM
  #457
ThinJim's Avatar
You guys are clowns.
I have some dyno news. It came out good until I ran out of injector. I had sieman212's in it for the pulls and they came up on 100% duty at 580rwhp at 19lbs boost. We started out very conservatively with 12lbs boost and worked our way up from there through a series of pulls. at 12psi it came in at 360, then bumped it up 5lbs with an actual psi of only 4lbs, to 16lbs. 4lbs boost gave me a remarkable 100+- hp. we then added another 5 and it gave us not quite 4ish psi. this time it increased hp 110+ to 580whp. we didn't have the tach hooked up so we don't know what the torque was. The target psi is 40 and then hit it with nos. eventually I will work myself upward with boost as this turbo is good to about 55-60psi, I would like to see what begins to fail at the higher boost range. the internals are sound, its the head gasket that is problematic. I will say, it revs like there's no tomorrow, cant wait to see how it sounds with 40. I know some of you will do the simple math to extrapolate hp, but it doesn't work that way.
I ordered some 500lb injectors and already started the install. I have to make a slight modification to the injector hole, and should have it up and running again soon, hopefully by weekends end. y'all take care.
Old Apr 8, 2010 | 06:09 PM
  #458
gnuts's Avatar
3.5 psi
amazing
  #459
Rajca's Avatar
that injector looks sweet. how much would 6 of those cost? any vids of the dyno pulls?
Old Apr 8, 2010 | 07:06 PM
  #460
civicdrivr's Avatar
The injector looks like a beast.
I want to hear it at WOT. Make a video.
Old Apr 8, 2010 | 07:22 PM
  #461
anthracitecl's Avatar
That injector looks sick! we need video!!!!!!!
Old Apr 8, 2010 | 11:22 PM
  #462
REDmanCL-S's Avatar
this really is redic kid. like everyone else, i would love to see a vid. I'll stay tuned!
Old Apr 10, 2010 | 01:20 PM
  #463
Allout's Avatar
Blown is Best
500 lb/hr injectors? That's freakin huge!
Old Apr 10, 2010 | 01:44 PM
  #464
ThinJim's Avatar
times 6! the 212lb ers weren't handling it. the major reason for the large injector is i converted it over to methanol. on the 212's for one pass on dyno used about a 1 1/2 gallons, this included some idle time etc. it's thirsty for sure. I'm pretty stoked on the numbers as it's going to make the mark.
Old Apr 10, 2010 | 04:49 PM
  #465
civicdrivr's Avatar
Im not sure if you posted this before, but is it still a 3.2l or did you stroke (or de-stroke) it?
Old Apr 10, 2010 | 11:02 PM
  #466
'01White3.2CL's Avatar
TellinItLikeItIsSince1/06
and there is no video because?!?!?! awesome numbers!
Old Apr 11, 2010 | 04:40 PM
  #467
nf3d0149ab's Avatar
Holy Shat Batman....
Old Apr 12, 2010 | 08:22 PM
  #468
ThinJim's Avatar
I left this one alone, it's a true 3.2.
Here are some pics of the work today, the intake is fully back on after some time consuming modifications. These injectors were just a slight bit on the short side compared with the previous injectors and got creative to make up the slack. I still have to work on mounting the new fuel filter which means re-routing the fuel lines and changing the size as well. While I had it apart, I adjusted the valves again as a couple worked themselves out of adjustment and re-torqued the heads, also changed the oil and cleaned everything out as well as inspecting the spark plugs. Everything looks good under the head covers and spark plugs were fine. After I tend to the timing belt, something is eating at it and frayed the edge and needs to be changed, I think it's ready for more psi. The plan now is to tune another 400hp into it and take it to the track to size it up. After that, I'll re-evaluate things and see how much farther to go.
I'll keep you all posted as I move forward.
Next time it's on the dyno, I'll post up a vid.
Old Apr 12, 2010 | 08:47 PM
  #469
Damn! It's just amazing!!!!!
Old Apr 12, 2010 | 08:52 PM
  #470
Rajca's Avatar
3.2 FTMFW
that thing is a monster
Old Apr 12, 2010 | 08:56 PM
  #471
DC3328's Avatar
Your Garage
how much can that belt take before it disintegrates/explodes/implodes?
Old Apr 12, 2010 | 09:01 PM
  #472
RUF87's Avatar
Lead Footed
[QUOTE=civicdrivr;11904830]The injector looks like a beast.
[QUOTE]
Images in the post are actual size.
I can't wait to see what numbers are finally put down.
Ruf
Old Apr 12, 2010 | 09:04 PM
  #473
Rajca's Avatar
what kind of coils are those?
Old Apr 12, 2010 | 09:20 PM
  #474
civicdrivr's Avatar
Jesus, the injector bodies are nearly the same size as the intake ports
Old Apr 12, 2010 | 09:37 PM
  #475
Got your mom in
Tom where do you do your dyno tuning?
Old Apr 12, 2010 | 09:41 PM
  #476
Allout's Avatar
Blown is Best
I like how you nonchalantly throw out there that you plan is to "tune another 400hp into it"
If i'm thinking about this correctly, you're headed to over 300hp per liter/displacement. I never would have imagined this territory
I was wondering how much fuel pump and fuel lines you would need to feed those injectors?
Old Apr 12, 2010 | 10:41 PM
  #477
Incredible. You need to get this on video when you race it
Old Apr 13, 2010 | 12:54 AM
  #478
civicdrivr's Avatar
Anyone else would the for his comment, but Thinjim clearly has the goods to back that up.
Old Apr 13, 2010 | 01:06 AM
  #479
Allout's Avatar
Blown is Best
Old Apr 13, 2010 | 07:05 AM
  #480
ThinJim's Avatar
It should be ok as long I keep an eye on it. Only time will tell.
[quote=RUF87;11916135][quote=civicdrivr;11904830]The injector looks like a beast.
Ruf
Hey Ruf, still perusing eh?
Honda CBR motorcycle coils. They won't work with your stock setup as these don't have the ignitor in them like the stock coils.
Rosado Racing WPB
There are 4 cylinders at the shop and they are putting over 250whp per hole on 2.2L motors! Although I'll never see that power per hole, it will be up there. The shop also does a lot of work on rotary motors that put a 1000 to the wheels, talk about nasty. I've come to respect the rotary as it's an amazing motor as well.
I'm using a Waterman mechanical fuel pump driven off the dry sump oil pump, attaches to the back of the oil pump. Its plenty big and will support more than this motor will ever deliver.
Here is a recent car from the shop on it's debut run at PBIR. This car is capable of running in the 6's, chassis is a rick jones piece and all other fab work is by Rosado Racing and JC Racecars.
