ATF Filter
Old Feb 12, 2010 | 09:52 PM
CollinCL's Avatar
ATF Filter
At the risk of sounding retarded. How do I change this out? I've only ever tried in the dark and I'm trying tomorrow during the day but I figure having some extra insight ahead of time will be nice. Do I even need to remove the bracket on top of it? If you can use the pics for a better description. Thanks.
Old Feb 12, 2010 | 09:59 PM
pits200's Avatar
Seriously, just start taking bolts out, if you take out to many, worst case scenario is you have to put in more bolts when putting it back together and it's a learning experience. You can't mess anything up by taking out extra bolts.
Old Feb 12, 2010 | 10:06 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
u gotta be confident in order to do any work on ur car u haven't done b4 or are not familiar with. so make sure u got ur jock strap on
Old Feb 12, 2010 | 10:12 PM
CollinCL's Avatar
It's not that I ain't confident. It's just the whole reason I work on my own stuff is to save money. I try to do all I can to prevent from breaking/stripping bolts, overtorqueing stuff, breaking clips, generally effing stuff up all in the effort to save money.
Old Feb 12, 2010 | 10:34 PM
i'm not knockin u man... I'm just reiterating the fact you need to just go ahead and do what need to be done.
W/e needs to be moved needs to be moved. there is nothing that can go wrong. so giver a whirl
Old Feb 13, 2010 | 12:45 AM
SYLKIE's Avatar
Wye-Ey-Fore Sicks-Spd
yes, you do hafta remove that bracket, and the two bolts holding it on. also, detach the other end of that small metal pipe so you can move it out of the way. after that, i think all you hafta do is unscrew the filter cartidge, if my memory serves me right. i dunno tho...it's been awhile since i did it, i forget.
Old Feb 14, 2010 | 10:04 AM
Rajca's Avatar
wham bam thank you ma'am
its simple. i did it in 20 min with the intake on. take the intake off for easier reach and more room to see what ur doing.
Old Feb 19, 2010 | 03:07 PM
PANAMARED's Avatar
very strange there is not a DIY on this... been searching, also going to change external filter soon
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
hashbrown
Sep 29, 2015 12:13 PM
