Ashtray light
Old Nov 5, 2002 | 11:22 PM
dunit_RENAMED's Avatar
Ashtray light
Is there a ashtray light on the 2002 CL ? Mine doesn't light up.
I had a 2003 TL loaner, and it lit up.
Old Nov 6, 2002 | 08:08 AM
NSXNEXT's Avatar
You have to buy the smokers package. That kit has a light.
Old Aug 12, 2003 | 07:34 PM
Smitty's Avatar
Damn... so is there a part number for JUST the light?
Smitty
Old Aug 12, 2003 | 07:36 PM
lou_RENAMED's Avatar
all you have to do is ground the solid red wire that goes to the light...the red with black stripe is 12 Volt.
Old Aug 12, 2003 | 07:37 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
lou, I would love to wire it...
How can we do that? is it tough?
Thanks.
Old Aug 12, 2003 | 07:39 PM
Smitty's Avatar
... thanks Lou... I knew I missed this awhile back so I went hunting with the search funtion.. I came across your post about it but the post just died without a resolution..
Smitty
Old Aug 12, 2003 | 08:05 PM
Smitty
the light comes with a green condom on it to dim the light a bit which I took off and makes it brighter
nighthawk the wires are already there disassemble the bottom portion of the dash and take off the piece around the shifter....then you will see the 2 wires on top that go to the light that lights up the ashtray....the 12 volt is already there all you have to do is ground the solid red wire and the ashtray will light up when you put you headlights on
this is without the green condom on the little light bulb.
Old Aug 12, 2003 | 08:14 PM
Happy CL-S Pilot
Which part should be disassembled?
Old Aug 13, 2003 | 02:58 AM
your main concern is getting part #18 out so you can work in back of it...in other words you dont have to take out the radio. You will have to take out the bowling ball trim and the side panels. Then you have to unscrew the armrest and just pull it back so you can pull out part #18
Lou
Old Aug 13, 2003 | 05:57 AM
NOLACLS's Avatar
Would someone have the HELMS pages on how to get to it on the 6spd??
Old Aug 13, 2003 | 06:07 AM
CT3.2's Avatar
The CL Crazy
I looked under there before i go hunting for the wire. It doesn't look like there's a light there. On the top there is just some grooves that are indented, is the light in there?
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
