Actuator fixed! HUGE DIFFERENCE!
Old Oct 20, 2004 | 10:18 AM
berny's Avatar
I need FI
For the ones that aren't sure if your actuator is working or not, go find out! I just got mine fixed and there is a big difference in power!
I love this forum!
Old Oct 20, 2004 | 11:25 AM
mrsteve's Avatar
Chaptorial's Avatar
Glad to hear you got it taken care of.
You just turned that CLP you were driving around in back to a Type S.
Old Oct 20, 2004 | 12:27 PM
Mike's Avatar
when are you going back to the track?
Old Oct 20, 2004 | 12:35 PM
phipark's Avatar
Not Asian
I love this forum!
How we YOU able to tell that it wasn't working? I know all about it, but I'm only to check by myself. If I turn it and I here it click, it means it's working right?
Old Oct 20, 2004 | 01:04 PM
gsrblack's Avatar
can you see the actuator on the '03 CLS 6 speeds? car's going in for my 30,000 mile service and wanted them to check it, but tried to look at it this morning and didn't see it. isn't it located on the driver's side, between the stock stb and the windshield?
Old Oct 20, 2004 | 01:06 PM
phipark's Avatar
Not Asian
it's basically right in the middle on the back. It should stick out like a sore thumb, it's almost the only thing there.
Old Oct 20, 2004 | 02:47 PM
gsrblack's Avatar
found it....mine works! pretty cool....it clicks pretty fast, either on or off, not gradual.
thanks for all the help!
Old Oct 20, 2004 | 03:03 PM
njtls's Avatar
it clicks when tyou turn on the car or when you rev it?
Old Oct 20, 2004 | 03:18 PM
Excelerate's Avatar
Former Sponsor
Here is a link to detailed info about the actuator.
http://www.geocities.com/~gamesmgr/chod/acura/#Driving6
Also, at 4100 RPM, the ECU signals a 12V actuator to open the secondary intake valve. So it happens when you rev the car up.
Old Oct 20, 2004 | 03:26 PM
LiQiCE's Avatar
Liquid Ice
I don't know how to do it without one person in the car revving the engine to 4100rpms and one person watching the actuator flip open and closed ... but there should be a way for you to pull the throttle body open/closed from the engine bay. I remember someone here saying they knew how to do it, but I never figured out what you need to do. That would allow you to rev up the engine while standing by the actuator and watch it open/close.
Maybe someone in the know can shed some light on the subject?
Old Oct 20, 2004 | 03:34 PM
Red-CL's Avatar
Doin' da crack shuffle
Congrats.
Old Oct 20, 2004 | 03:39 PM
phipark's Avatar
Not Asian
mirrors?
Old Oct 20, 2004 | 04:01 PM
01bluecls's Avatar
"You my boi blue!"
When trying to click on the link and view pics of the actuator, the link times out and basically doesnt work. Any other links of pics of the actuator?
Old Oct 20, 2004 | 04:21 PM
01bluecls's Avatar
"You my boi blue!"
Nevermind, i found the pics that i needed with the wonderful button called SEARCH! Just checked mine....it works just fine.
Old Oct 20, 2004 | 09:47 PM
Allout's Avatar
Blown is Best
It's easily done. You can operate the throttle body manually from under the hood. It has cables running to it. Just rotate it and the engine RPM will increase.
Old Oct 20, 2004 | 09:48 PM
mrsteve's Avatar
I told you at the last meet. Remove the engine cover and turn the brass colored assembly connected to the throttle body. That will rev the engine
Old Oct 21, 2004 | 05:26 AM
LiQiCE's Avatar
Liquid Ice
I'm stupid, I need pictures
Old Oct 21, 2004 | 10:06 AM
bigman's Avatar
'Big Daddy Diggler'
wow, if you dont know how to rev the motor by using the throttle cable, you shouldnt really be fiddling around under there. J/K
tman570
Jun 11, 2019 07:56 AM
justin7779
Dec 25, 2015 10:33 PM
Azonics
Sep 22, 2015 05:28 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
kuzdu
Sep 10, 2015 08:42 PM
