6 Speed Trans
A-CL Member
6 Speed Trans
I test drove a six speed and seemed like an unbalanced (vibration)clutch/pressure plate isssue. Also the clutch seemed way too tight. This turned me off from buying one. Yes, I got the auto. Does anyone know of a scanner (OBDII) that will clear the memory?
what do you mean by clear the memory?
what, did you hit the rev limiter.
it doesn't matter.
i've probably hit the rev limiter more times than you've driven your car.
i doubt the ecu keeps track of that kind of info.
Sweet as Gold
well...you have to over-rev like a bitch to set a code...just hitting the rev-limiter won't set it but if you ride w/ it over-reving or something youy will set a code for over-reving the motor...I've seen it before. As far as the clutch feeling too tight or whatever...there might have been something wrong w/ the car you testdrove...there should not be any vibration at all...if there was it might have been something small as wheel balance or warped rotors or even a wheel bearing but not likely your trans...
joflewbyu2
10-08-2015 11:16 AM
flyromeo3
09-24-2015 11:24 PM
