6 Speed Trans
Old Oct 11, 2003 | 06:25 PM
Daniel M CL/TL's Avatar
A-CL Member
6 Speed Trans
I test drove a six speed and seemed like an unbalanced (vibration)clutch/pressure plate isssue. Also the clutch seemed way too tight. This turned me off from buying one. Yes, I got the auto. Does anyone know of a scanner (OBDII) that will clear the memory?
Old Oct 11, 2003 | 06:32 PM
mattg's Avatar
what do you mean by clear the memory?
Old Oct 11, 2003 | 06:34 PM
A-CL Member
The over rev memory
Old Oct 11, 2003 | 06:38 PM
mattg's Avatar
what, did you hit the rev limiter.
Old Oct 11, 2003 | 06:40 PM
A-CL Member
No I want to know how in case I do
Old Oct 11, 2003 | 06:42 PM
mattg's Avatar
it doesn't matter.
i've probably hit the rev limiter more times than you've driven your car.
i doubt the ecu keeps track of that kind of info.
Old Oct 12, 2003 | 01:06 PM
6speedctrlfreak's Avatar
:shakehd:
Old Oct 12, 2003 | 01:51 PM
allmotor_2000's Avatar
I have one... made by Equis -> not sure how its spelled... let me look at it end tell you
Old Oct 12, 2003 | 03:15 PM
A-CL Member
Does anybody else with a 6 speed trans CLS have vibration?
Old Oct 12, 2003 | 03:16 PM
A-CL Member
LOL
Old Oct 12, 2003 | 03:19 PM
amisconception's Avatar
werd
I didn't think the clutch was too tight...
Old Oct 12, 2003 | 08:16 PM
Ant7701's Avatar
Sweet as Gold
well...you have to over-rev like a bitch to set a code...just hitting the rev-limiter won't set it but if you ride w/ it over-reving or something youy will set a code for over-reving the motor...I've seen it before. As far as the clutch feeling too tight or whatever...there might have been something wrong w/ the car you testdrove...there should not be any vibration at all...if there was it might have been something small as wheel balance or warped rotors or even a wheel bearing but not likely your trans...
TypeS860
Jan 10, 2026 11:11 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
LeVeL
Oct 18, 2015 04:19 PM
joflewbyu2
Oct 8, 2015 11:16 AM
flyromeo3
Sep 24, 2015 11:24 PM
