2001-2003 Acura CL Wiring Diagram
This is for alarms and remotestarts. - walkthrough soon to come
Moderator: Please Sticky This
DISCLAIMER: This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
WIRE COLOR POLARITY LOCATION
12volts white + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory white/black + ignition harness
Keysense blue/white - ignition harness
Power Lock black/blue - passenger fuse box
Notes: Located in a blue or gray 22 pin connector in front of the passenger fuse box. Use the key switch in the passenger door to test.
Power Unlock orange - passenger fuse box
Lock Motor white/red 5wi 18 pin grn plug, driver fuse box
Unlock Motor yellow 5wi 18 pin grn plug, driver fuse box
Parking Lights+ red/black + 4 pin grn plug top of pass. fuse box
Parking Lights- red/yellow - headlight switch
Hazards same as turn signals
Turn Signal(L) green/blue + steering column
Turn Signal(R) green/yellow + steering column
Reverse Light green/black + 2 pin brn plug below pass. fuse box
Door Trigger black/white - 4 pin grn plug top of pass. fuse box
Dome Supervision use door trigger
Trunk/Hatch Pin blue/green - 22 pin grn plg left of dri. fuse box
Hood Pin yellow - lt. blue plug below pass. fuse box
Trunk/Hatch Release white + passenger MUX module
Notes: The passenger MUX module is located behind the glove box.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock black/red to blue - driver door key cylinder in door
Tachometer blue ac tach test connector
Notes: The tach test connector is a 2 pin connector near the air intake on the driver side shock tower.
Wait to start N/A
Brake Wire white/black + brake pedal switch
Parking Brake green/red - lt. blue plug below pass. fuse box
Horn Trigger lt. green/blue - steering column
Memory Seat 1 lt. blue - memory switch in door
Memory Seat 2 blue - yellow - memory switch in door
Memory Seat 3 N/A -
Interface Module:
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: When using the 556HW, follow the mode 2 wiring diagram. The reference wire is brown/yellow, data 1 wire is red, data 2 wire is blue/white and ignition wire is yellow/black.
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Wait to start N/A
Memory Seat 3 N/A -
Interface Module:
Part #: 556HW
DFW AREA,
http://www.the12volt.com/installbay/vehicles.html they have wiring diagrams for most cars check them out.
i got the wire sheet, but i had to search for hours for it.
i dont think i should give it to azine, not even for a sticky
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
alan_rich
09-07-2015 11:08 PM
