02 Foglight Question
Old Oct 13, 2010 | 03:36 PM
MIKE8898's Avatar
Bonki Ehrite!
My fog lamps or running lights(whatever they technically are called) are not working. Hoping it is just a fuse i checked my fuse box on the driver side of the dash where the panel pops off. There are a few missing fuses on that side. Does anyone know if one of these fuses could be the resason they are not turning on? I don't have a manual for the car. Thanks alot.
Old Oct 13, 2010 | 05:39 PM
civicdrivr's Avatar
Your headlights are on right?
Old Oct 13, 2010 | 06:23 PM
MIKE8898's Avatar
Bonki Ehrite!
Yeah. Headlights work fine its just the fogs that are out. Why? Are they run from the same fuse?
Old Oct 13, 2010 | 06:31 PM
civicdrivr's Avatar
The road lamps only come on if the headlights are on, thats why I ask.
Old Oct 13, 2010 | 06:35 PM
MIKE8898's Avatar
Bonki Ehrite!
Oh yeah I knew that lol. But they should be on at all times when the headlights are on since there is no switch for it right?
Old Oct 13, 2010 | 06:36 PM
civicdrivr's Avatar
Should be.
Are you sure the bulbs arent blown?
Old Oct 13, 2010 | 07:04 PM
MIKE8898's Avatar
Bonki Ehrite!
No. Since both are not working I couldnt swap them and see. I was just hoping someone might know which fuse it is before i spend money for new bulbs or HIDs.
Old Oct 14, 2010 | 12:22 PM
aznboi2424's Avatar
They are 194 bulbs, you can take the ones from the door, maplight or trunk and they would fit. Thats the cheapest way to test if the bulbs are blown without buying a pack of bulbs.
Theres no fuse for them specifically.
Old Oct 14, 2010 | 02:54 PM
MIKE8898's Avatar
Bonki Ehrite!
Thanks for the info aznboi. I will try the ones from the trunk later today.
Old Oct 14, 2010 | 07:37 PM
aznboi2424's Avatar
I think its easier to remove the maplight or door bulbs then the trunk but its up to you. The license plate light is also a 194
Old Jul 3, 2011 | 12:51 AM
ddecerchio's Avatar
just bringing this thread back.. my car has the same problem but i know for a fact the bulbs arent blown. both lamps just stopped working so i replaced both bulbs and nothing. Its driving me crazy trying to find out whats wrong! HELP!
Old Jul 5, 2011 | 03:26 PM
aznboi2424's Avatar
Check the wiring, you may have a break somewhere.
Old Jul 7, 2011 | 07:13 PM
ddecerchio's Avatar
are the road lamps wired seperately? its weird that would both just suddenly stop working
Old Jul 12, 2011 | 05:25 PM
aznboi2424's Avatar
Yea, they are both wired to the headlights I believe
Old Jul 13, 2011 | 12:41 AM
ddecerchio's Avatar
i figured that since they come on with the headlights. but shouldnt my headlights not come on either if it was a wiring problem?
Old Jul 13, 2011 | 02:54 PM
aznboi2424's Avatar
Your headlights are wired to a relay. The roadlamps are wired to the headlights. Your roadlamps would not turn on only if you received no power to the headlights.
Old Jul 13, 2011 | 03:12 PM
ddecerchio's Avatar
so if my headlights turn on and the roadlamps dont, and i know the bulbs arent bad, what do you think is the problem?
Old Jul 13, 2011 | 05:56 PM
vaymoon's Avatar
If you like i can get you a wire diagram.
Old Jul 13, 2011 | 06:03 PM
vaymoon's Avatar
Old Jul 19, 2011 | 02:10 PM
aznboi2424's Avatar
A break in the wiring between the headlights and the roadlamps.
Old Jul 20, 2011 | 12:27 AM
vaymoon's Avatar
Did you fix the problem?
Old Jul 20, 2011 | 01:06 AM
ddecerchio's Avatar
No i havent got around to it since ive been working non stop for the past couple of days but i have off on thursday so that sounds like a good day to give it a go lol
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
