01'CLS Vs. G35 coupe 6speed
i have 01' auto cls
intake header exhaust
tranny cooler in trunk(should have put it on today)
he was G35 coupe 6-speed
k&N filter
85 degrees, probably shouldn't have been racing anyhow...
raced a few times. best race was from 25 to 115. he put a headlight on me right at 115 and then we shut down. i know he would keep pulling cause of gearing but it wasn't too bad in my mind, i thought i would have gotten beat much worse.
k&N filter
Originally Posted by darrinb
great runs, from a 25 roll u got the advantage cause the G is gonna be in 2nd and you'll have a sweet 1st gear roll
Run him from a stop next time. :P
Originally Posted by Brady6226
i have 01' auto cls
k&N filter
k&N filter
up to 115? AT CLS are dogs after 100 and i am suprised that he didnt pull away from u after 100mph because G35 6speed are quick all the way up to 130.
good run.
Originally Posted by scalbert
But didn't you go from a CL-S 5AT to a G35C 6MT... Big difference when gearing is applied.
But Darrin stated that the CLS has the advantage at a 25mph roll.
I was just stating my own experiences...
Well since we are talking about gearing...
My RX7 did 1st 35, 2nd 65, 3rd 95, 4th 140 (YEAH BABY!!), 5th i only went up to 160 before i ran out of road.
Plus RX7's don't have a rev limiter, they have a "shift now" suggestion beep. You could ignore it and keep going for a lil more.
Thats nearly identical to the gearing in the CL-S6 Darrin
CL-S6 with OE tire sizes
1st- 40mph
2nd- 64mph
3rd- 93mph
4th- 127mph
5th- 162mph (yeah right)
6th- 206mph (bwahahaha)
Those are assuming 6900 redline, 215/50/17 tires, and 3.286 final drive ratio (6 speed).
Its such a pity that you have to upshift at 93mph. I'm sure they dont care about 1/4 gearing though.
I wish they made 4th a little shorter so at least it didnt have such a dramatic falloff compared to 3rd, or make third a touch taller so we didnt have to upshift 100' before the traps.
I feel sorry for you 5AT guys though, your 4th gear is barely shorter than 6th gear in the CL-S6.
1st- 40mph
2nd- 64mph
3rd- 93mph
4th- 127mph
I wish they made 4th a little shorter so at least it didnt have such a dramatic falloff compared to 3rd, or make third a touch taller so we didnt have to upshift 100' before the traps. I feel sorry for you 5AT guys though, your 4th gear is barely shorter than 6th gear in the CL-S6.
1st- 40mph
2nd- 64mph
3rd- 93mph
4th- 127mph
1st- 40mph
2nd- 64mph
3rd- 93mph
4th- 127mph
Very good point, I hadnt considered the extra rpms the J32 carries.
Lets just say that for arguments sake though that since the VQ35 holds a significant low end tq advantage that it cancels out the extra rpms that the J32 has.
Here's the overall ratio's for each car.
CL-S6 ------ G35C 6 speed
1. 12.923 ----- 13.423
2. 8.142 ----- 8.222
3. 5.586 ------ 5.745
4. 4.107 ------ 4.496
5. 3.207 ------ 3.538
6. 2.533 ------ 2.809
As you can see it has a slighty shorter gearing and a lower redline, thus it has a lower top speed in each gear relative to the CL-S6. It has better gearing for 1/4 mile racing because 4th is a little steeper and it finishes at the traps at 5700 (900 rpm before redline) whereas the CL-S6 finishes in 4th at 5300 rpm (1600 rpm before redline).
If the CL-S6 had identical gearing to the G35 it would probably be just as fast and actually trap higher and there wouldnt be the average 3 tenths difference between the G35C 6 speed & CL-S6.
JMO, dont take it for fact, especially if you dont know wtf I'm talking about.
maybe the cl-s6 is geared so when ya shift it falls right back to the beginning of vtec
CL-S progression 01
Jan 26, 2016 04:15 PM
STL TL-S
Sep 23, 2015 08:52 PM
so i know how it is.
