Windshield Washer Not Working!
Old Dec 31, 2008 | 09:27 AM
PNJBi's Avatar
Hi,
My Winsdshield Washer Fluid sprays intermittently. Sometimes it will spray and sometimes it won't. I might get lucky and it'll spray out once or twice and then it won't spray until the next time I start the car. I don't think the nozzles are clogged. The fluid is there. Any ideas on what might be causing the problem? It's an 04 TSX with 90k on it.
Old Dec 31, 2008 | 10:04 AM
moda_way's Avatar
Originally Posted by PNJBi
Hi,
Trace the line back to the pump, meaning, remove line from each nozzle and see if you get pressure when you use the sprayers. Work your way back until you do find pressure, then you've located a blockage or a kink. If you never get pressure all the way back to the pump, then its the pump or the pump relay.
Old Dec 31, 2008 | 10:59 AM
jim13's Avatar
that happen to me once but i found out that the fuse blew, if you want you can try changing the fuse and see if the washer works or not, or yeah try seeing if its clogged or anything like that first
Old Jan 4, 2009 | 05:32 PM
TSXer04's Avatar
3rd Gear
id check the tubes running to your sprayers. often times on older vehicles they simply become clogged from dirt, cant imagine that on a newer car though. try getting fluid out by vacuum too after removing hoses from squirters. good luck!
Old Jan 5, 2009 | 11:36 AM
LukeaTron's Avatar
With the key in the "on" position but without the engine or HVAC running, see if you can hear the pump motor running when you pull the lever. It's not particularly quiet so it shouldn't be hard. If you don't hear anything check the fuse. If that's fine there's a problem either with the pump itself or the wiring. If you've got the mechanical aptitude you can proceed diagnosing the issue there. If you don't know how to do that, you should take it somewhere and have it checked as it's not the kind of thing that can be easily pulled off without really knowing what you're doing.
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
acurajj
Sep 19, 2015 03:47 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
08 NBP TL
Sep 8, 2015 08:49 PM
