dip stick question
Old Jan 5, 2009 | 08:38 PM
yaze21's Avatar
D.L.T
dip stick question
well my question is madd simple...im trying to do drain my tranny like soon cuz i went to do my oil change n they said it needs to get done, well i kno i have to drain it all from the bottom but i dont seem to find where the heck i can put it back in..so can i just get a tube or something n start putting some tranny oil through there? ( DIP STICK, that yellow thing )..like no problems?
Old Jan 5, 2009 | 08:54 PM
JTso's Avatar
Yes, you can use a funnel with a tube and add the ATF down the dipstick opening.
Old Jan 5, 2009 | 11:45 PM
goddsmack's Avatar
Originally Posted by yaze21
...start putting some tranny oil through there? ( DIP STICK, that yellow thing )..like no problems?
Yeah but just make sure you don't overfill and you use the Genuine Honda ATF. I forget what the speciality of Honda ATF, but I seem to remember something about friction and all that. About 3.0 qt if it's a simple spill & fill.
Also, with Honda you can check the level with the engine off.
Old Jan 6, 2009 | 10:43 AM
yaze21's Avatar
D.L.T
thAnks guys well correct me if I'm wrong so drain n fill it with 3qts then drive the car for few mins then drain Again n fill oh and is also best 2 buy that ring round thing that goes in between the drain bolt right? thanks again
Old Jan 6, 2009 | 10:55 AM
jlukja's Avatar
FYI, 2 drain/fill cycles replaces around 65% of the ATF while 3 drain/fill cycles replaces around 85%.
LukeaTron's Avatar
Do you meant the washer? If so yes, always replace those when changing fluids. They are one time use items.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
