window seal squeek on an '07
Old Oct 3, 2007 | 01:26 PM
GhostMeat's Avatar
I just did a search on my window seal squeek and came up with a few hits on '04 window squeeking. nobody mentioned a solution.
Is this something i can take to a dealership and somehow get them to fix? Or is it as stupid-easy as just putting some kind of lube inside the window seals?
Old Oct 3, 2007 | 01:29 PM
mltk53's Avatar
I can't find my garage
uhhh i was once told putting lemon on it helps, but it an 07, warrenty it
Old Oct 4, 2007 | 03:54 PM
alucardx's Avatar
i cleaned all 4 sides of where the edges of the glass slide up (sides) and into (top/bottom) with the edge of a rag. squeel went away.
Old Oct 6, 2007 | 06:46 PM
DixonTSX's Avatar
I had something similar happen in my '04 TSX, and they replaced the window actuator or something (under warranty work), apparently is the part that controls the window going up and down, they also lubricated all the necessary areas.
Old Oct 11, 2007 | 03:49 PM
jlukja's Avatar
squeak
Maybe you should have spelled it correctly.
You can take it to the dealership and they will "lube" the window seal channels. It will work for 3-4 months and then slowly come back. Some folks recommend using spray silicone lubricant, which worked for me for only 2-3 weeks. Apparently the dealer uses a thicker version, something like silicone grease. It lasts longer but not forever.
Old Oct 11, 2007 | 08:30 PM
ruber0id's Avatar
Originally Posted by jlukja
squeak
Ha-ha, shouldn't it be a part of scheduled maintenance?
Old Oct 22, 2007 | 03:15 PM
GhostMeat's Avatar
squeak
Bah! I use the British spelling. ehhhh....yeah...uh...that's it. ;-)
Old Oct 22, 2007 | 04:04 PM
khmy2nr's Avatar
White-Ebony-6spd
I have an 07 and I do get the squeek on the drivers side. Washed it up real good on the inside with stoners and no more sqeeks for the last 5 months.
Old Oct 22, 2007 | 08:01 PM
Saeyon's Avatar
detour
i have a 08, i just called today gonna take it to the dealership on thursday for them to fix my "window squeaks"
le^2
Mar 17, 2026 05:06 AM
Mike734
Dec 10, 2021 01:25 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
