Wheel stud and hub removal
Old Jul 13, 2011 | 10:57 PM
azndoritos209's Avatar
I recently messed a 2 of my wheel studs and am going to replace them. I know that i have to remove the hub in order to have enough clearance in order to remove the studs. My question is if i bring my spindle to a shop to have the hub pressed out, will i have to replace the bearing also? Because on my previous honda when i pressed out the hub the inner part of the bearing came out with it.
Old Jul 14, 2011 | 03:19 AM
PaHonda's Avatar
Is this the front or back wheel studs?
Old Jul 14, 2011 | 11:30 AM
This is for the front.
Old Jul 14, 2011 | 11:40 AM
PaHonda's Avatar
You should ask the machine shop, because I have never done this on my TSX.
The bearing may or may not get damaged. Replacing the bearing will guarantee that you won't have any problems.
Old Jul 16, 2011 | 08:44 AM
gdcwatt's Avatar
Not an expert, but, how badly did you mess up the studs? A year ago my TSX came back from a dealer service, and a month later, when I went to change the snow tires to summers, I noted a problem with one of the studs, when I tried to take it off. I should have gone back to the dealer with just 4 lug nuts on, but I put on the 5th one, too.
I was pushing for a hub replacement, but the technician just ran a thread chaser over it, and it's been fine ever since.
Old Jul 16, 2011 | 02:44 PM
I can do what you said to one of the studs but other had a piece come off with the lug nut. I took off the entire spindle and taking to get pressed on monday with the new studs.
Old Jul 18, 2011 | 02:44 PM
Finally talked to the guy at the machine shop an turns out that you have to change the bearing when removing the hub.
Old Jul 22, 2011 | 10:24 PM
LECKEY73's Avatar
You take the chance of it going bad when pressing it out or when going back in. It is better to change it.
cycdaniel
Dec 17, 2019 10:58 AM
obert
Nov 14, 2015 09:59 PM
merc009
Oct 3, 2015 12:59 AM
DUECE_DXJ
Sep 24, 2015 04:54 PM
mtl_ilx
Sep 3, 2015 09:48 AM
