Warped rotor, will it because of my rims?
I just found out my rotor is warped. My rims are slightly bent, so will it be the reason? should I put the oem wheels back before bring it back to dealer? if yes, it will be a lot of work since my oem rim are on winter tire now!
providing that your rotor is warped and vibration is not from the rim. then nope. your warped rotor should has nothing to do with ur bent rim. Acura/honda rotors are known to warp. just get it resurfaced at any service station then u are good as new.
Originally Posted by Viking
How do you know your rotors are warped? Your bent rims might be causing wheel vibration.
boy. ur all jacked up huh.. get a new rim.. i dont trust fixing bent rim... its never the same once its bent. u know how that goes. and justget ur rotor surfaced then ull be fine. my philosophy is... if money can buy u safety and peaceof mind. then its worth it.
might as well get them replaced .....u can only resurface a rotor once and that decreases the life of the rotor....the next time it warps u can't resurface again....so just get it replaced if itz under warranty
Our rotors suck. My are major warped, but I'm waiting to replace with a special set... soon to be documented here.
Mine are getting there too and I only have 35000KMs on it. Time to get them warrantied!!
oh yeah, btw take your rims off before going to the dealer, the mechanic working on your car would be much happier!!
When I braking on high speed, the brake padel and the car are all shaking, so I know my rotor is wrapped. When I running my car on highway speed and my steering wheel is vibrating than it is my rim bent or wheel is out of balance. But I am sure my rims are slightly bent because I bought it used and have it proof it is bent from the wheel balancing machine.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
