VSA , check engine, triangle and park and drive lights on
Old Jun 29, 2019 | 08:59 AM
Carlos Diaz's Avatar
Lately i will be leaving from a parking lot and the Park and drive light from the instrumental cluster will be on in the same time, vsa light on, and check engine light, code is solenoid b circut low, and it appears that i go into limp home mode. Any ideas what could be wrong?
Old Jun 29, 2019 | 09:08 AM
the check engine light is a clue,go get that code read from an auto parts store....
it will tell you whats wrong
Old Jun 29, 2019 | 09:10 AM
But I forgot to mention, i turn it off it goes away, check engine light stays on, but goes away later, runs normal to
okay, it's still a clue, go get the code read...
Old Jun 29, 2019 | 11:13 AM
TexasHonda's Avatar
Circuit fault indicates faulty solenoid, wiring or connector. Since problem resolves itself, it's an intermittent. Diagnostics w/ a VOM are necessary when problem is present.
good luck
Old Aug 9, 2019 | 07:26 AM
Leon1892's Avatar
Alternator
Same thing happen to my 06 tsx. Bad alternator.
josiel
Feb 10, 2020 01:49 PM
TLinMN
Apr 16, 2015 11:16 AM
ABP_04TL
Oct 24, 2009 01:18 PM
GaddAMIT
May 28, 2004 03:28 PM
sgriffin
2G CL Transmission Recall Q & A
Feb 24, 2004 07:40 PM
