Severe engine vibration at idle/park
Old Aug 12, 2019 | 12:03 AM
MidnightMechanic's Avatar
2004 TSX 5 speed auto. I first replaced all of my motor mounts since they were all broken, and this improved the problem some, however I used aftermarkets from eBay that were incredibly cheap. It has 220k so I replaced the timing chain and balance shaft chain, and their tensioners, as this had cleared up a vibration problem on my 03 k24 accord. Sadly this did not resolve it, so I proceeded to replace the plugs, remove and inspect the MAP sensor, clean the throttle body, change the trans fluid 3 times (I once read a post suggesting the torque converter can cause this), and finally I vacuum tested the front vacuum operated motor mount which I had just replaced, and it wouldn’t hold a vacuum. I capped off the vacuum control solenoid so that there would no longer be a vacuum leak there (I thought perhaps the unmetered air was throwing the A/F ratio off far enough cause the shaking) but again, no improvement. Does anyone have experience with aftermarket vs OEM Acura front motor mounts performing differently? And this is a severe vibration with no engine codes. The steering wheel bounces, basically the whole front of the car bounces hard. I’ve read many posts across the web on this but none that documented an accurate diagnosis and the subsequent solution.
Old Aug 12, 2019 | 09:45 AM
losiglow's Avatar
Wow. You did just about everything. How's the mileage and power? Any codes popping up? Misfires or bad valves could cause that but you'd have a CEL in that case. Any funny smells from the exhaust? Oil or coolant consumption?
rthammer
4G TL Problems & Fixes
Jan 12, 2014 09:53 AM
tastytreats
2G TSX Problems & Fixes
Mar 23, 2012 08:55 PM
golfer04
Dec 21, 2011 09:18 AM
TL6SPD
Oct 6, 2011 12:42 AM
TL6SPD
Sep 12, 2011 01:32 PM
