trunk release fuse problem...
Old May 27, 2007 | 04:28 PM
shortyyy's Avatar
I have a 04 tsx and the trunk release doesn't work from the outside or from pressing the button on the alarm. I believe it has something to do with the fuse, but i don't have the user's manual...does anyone happen to have it and is willing to share?
Old May 28, 2007 | 10:54 AM
poltergeist's Avatar
There is no individual fuse for the trunk release solenoid. The solenoid is energized when commanded by the Multiplex ICU (basically the body control unit). Fuses #7, 8 & 21 in the underdash fuse box are power supply fuses to the MICU.
More likely you've got a bad input into the MICU (like the doors aren't unlocking), a failed solenoid, or a broken wire (possibly the harness at the left trunk hinge--has the recall been done for the wire harness?).
Old May 28, 2007 | 12:17 PM
Xtremespeed2102's Avatar
is the switch turned in the glove box?
Old May 29, 2007 | 01:11 AM
shortyyy's Avatar
ahhhh well its definitely not the trunk switch cause i checked that, but basically someone i know took a look at it and decided with a manual he would be able to see what things control what. Thanks though i'll mention what you said poltergeist to him.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
