removal of interior lights
Old Dec 15, 2006 | 10:27 PM
bchang2001's Avatar
how do you remove the plastic piece that has the sunglass holder and the homelink?? i know that there are 2 black bolts under the sunglass holder but the bottom half still feels very secure.
do i just pull it off or is there another screw that i have to unscrew.
thanks
Bryan
Old Dec 15, 2006 | 11:38 PM
poltergeist's Avatar
1 screw above each of the maplight lenses.
Old Dec 15, 2006 | 11:48 PM
San-AnT's Avatar
The Power of a Grill
for removal of the interior lights? you dont need to take out that part. are you trying to take out the ambient light?
Old Dec 16, 2006 | 12:14 AM
bchang2001's Avatar
im actually trying to get to the power supply behind so that i can tap into it.
how do i get to those 2 map light screws??
Old Dec 16, 2006 | 12:16 AM
Ride Slow Homey's Avatar
AlwysCleanURArely c ASpec
hmm what are you trying to do to that power source
Old Dec 16, 2006 | 12:18 AM
bchang2001's Avatar
i need to tap into it so that i can power my valentine one.
Old Dec 16, 2006 | 12:38 AM
ehh i dunno what a valentine one.. im sure someone might know how to do this though
Old Dec 16, 2006 | 12:48 AM
bchang2001's Avatar
i just need to take off that plastic peice that holds the sunglass holder, homelink, and map lights. i know how to tap the wires.
Old Dec 16, 2006 | 12:03 PM
San-AnT's Avatar
i think there is a DIY around here somewhere for a valentine. i think they just tapped in to the wiring behind the mirror
Old Dec 16, 2006 | 01:36 PM
hackbart's Avatar
This is exactly the info I'm looking for, too. In my 200SX SE-R I just tucked it into the headliner and ran it behind the pillar to the fuse box, but with the airbag stuff I am afraid to try that on my new TSX.
I did find this:
There is already wire running down the side. You can just run it parallel with that wiring. Just zip tie or tape it up. It's pretty easy. Also, to remove the a pillar, just use a butter knife to get underneath the SRS clip and pop it up. Then just slide it out and up.
https://acurazine.com/forums/showthr...ight=valentine
Old Dec 17, 2006 | 10:42 AM
hackbart's Avatar
If you have Valentine1, Beltronics, or Escort you might be able to use this:
http://www.invisicord.com/install.html
I found it on this thread:
https://acurazine.com/forums/showthr...ht=mirror+wire
I'm going to try this.
Old Dec 17, 2006 | 11:33 AM
bchang2001's Avatar
i was just going to tap into the homelink power.. does anyone know which color supplies power when the key is in the on position? bascially looking for the wire that is not constant power.
Old Dec 17, 2006 | 02:29 PM
Homelink power circuit is hot at all times, as are the lights in the overhead console.
Old Dec 17, 2006 | 09:12 PM
bchang2001's Avatar
oh... so the only place is teh fuse box on the bottom?
Old Dec 17, 2006 | 10:53 PM
As mentioned above, hot with key "on" is available at the auto day/night mirror wire harness
Old Dec 18, 2006 | 01:06 AM
bchang2001's Avatar
where are you guys putting the ground??
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
