Rack and pinion leak - replace whole unit?
This morning the mechanic found an internal leak in rack and pinion on my TSX 2004. P/S fluid was very low and he could feel fluid inside one of the rubber boots of rack and pinion. He said R&P has to be replaced as a unit, about $400 labor and $$ for parts. I thought he can take it apart and replace a seal or something but he said it is only replaced as a whole. Does it sound about right?
S
S
The boot is to keep dirt out, not keep the fluid in. The fluid will just leak past the boot. In many cases, the boots have little drain nipples to prevent fluid from building up (and collecting dirt which can damage the fluid seals).
What you should be worried about is the seal giving out completely and losing all the pressure in your power steering. You'd still be able steer the car, but at lower speeds it would take significantly more effort.
cycdaniel
12-17-2019 10:58 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
yahelou
09-06-2015 09:12 PM
