Parking break light?
Old Sep 9, 2008 | 02:20 PM
TSXGOTME's Avatar
My parking break light keeps coming on randomly when I’m driving I haven’t taken my TSX to the dealer yet but I was just curious if this has happened to anyone and if its a quick fix.
Old Sep 9, 2008 | 06:12 PM
MrHeeltoe's Avatar
Former Sponsor
Brake fluid is low...probably need new brakes soon.
Marcus
Old Sep 11, 2008 | 12:59 PM
TSXGOTME's Avatar
It could be the break fluid being low but I don’t know about new breaks I just replaced the rears a couple of months ago and the fronts about a year ago. The light only turns on when I’m breaking to a complete stop I wonder if the parking break needs to be adjusted in some sort of way
Old Sep 11, 2008 | 01:35 PM
MMsTSX's Avatar
JDM Addict
I think you're off.
I doubt it's your parking brake.
that is NOT a parking brake light.
it's for all of the brake system, not just the parking brake.
I would first guess something is wrong with fluid.
On my list of things to check, personally, the parking brake would
be near the end of it.
check your fluid levels first.
Old Sep 11, 2008 | 01:41 PM
davidspalding's Avatar
Make a hole, coming thru!
pp 63, 334 (2007 OM). This is not an annoyance ... you want to check this out fast, for safety reasons.
Old Sep 11, 2008 | 05:07 PM
MrHeeltoe's Avatar
Former Sponsor
Its not break, its BRAKE!
As the fluid in the reservoir drops there is a float inside that drops and when it gets to a certain point the light goes on. Fluid sloshing around moving the float up and down would make this consistent with the light going on and off.
The fluid is low. Check under the hood. It takes two seconds. Prove me wrong.
Marcus
Old Sep 11, 2008 | 05:31 PM
Thumbs up
Originally Posted by MrHeeltoe
... The fluid is low. Check under the hood. It takes two seconds. Prove me wrong.
Old Sep 11, 2008 | 06:21 PM
tsx 2 nv's Avatar
ridiculously good looking
or maybe a brake light bulb is out?!?!
Old Sep 12, 2008 | 02:53 PM
TSXGOTME's Avatar
Marcus
You could be right I checked and the brake fluid its just above the minimum line I didn't have any on hand but it does make sense since it only turns on when I’m braking and then it turns off once I’m standing still.
Old Sep 12, 2008 | 03:08 PM
PACman's Avatar
Honda DOT 4 brake fluid, about $5-6/bottle.
Old Sep 12, 2008 | 03:17 PM
MrHeeltoe's Avatar
Former Sponsor
Hehe, I just might be
Honda has DOT 4? I thought it was DOT 3.
Get this one! Check the front brakes tho...usually the fluid drops when the brakes get worn down.
Marcus
Old Sep 12, 2008 | 03:31 PM
PACman's Avatar
Marcus
What, you mean you don't use DOT 4?
Kidding.....Yea, my bad, ...DOT 3. I get mixed up.
Old Sep 15, 2008 | 05:08 PM
TSXGOTME's Avatar
I did a bit more research and stumbled on to this I wonder if this could be a fix for both my parking brake light coming on and now my VSA light came on
Old Sep 15, 2008 | 05:36 PM
PACman's Avatar
Did you stumble upon this too? https://acurazine.com/forums/1g-tsx-problems-fixes-128/help-vsa-%5C-brake-lights-not-working-685749/
Old Sep 16, 2008 | 04:38 PM
TSXGOTME's Avatar
Originally Posted by PACman
Sorry I was in a hurry and didn't post the link but the symptoms sound alike unfortunately the closest dealer is 30 minutes away so Ill have to visit the dealer on Friday
Old Sep 22, 2008 | 08:29 AM
TSXGOTME's Avatar
Finnaly I think I fix both the issues with the brake light coming on when I came to a dead stop and my VSA /!\ light. I wanted to cover all bases I got some brake fluid and a brake switch very simple It looks like it works but that was since friday so I got to keep my eye on those lights to make sure they don't come on any more
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
